Hi all, I'm watching Tivo2Go files (.tivo) in WMP11 and it looks like WMP is using the "ffdshow mpeg-4 video decoder". It plays fine and everything, but the picture quality isn't as good as it could be; it desparately needs to be deinterlaced. See an example here:
http://i153.photobucket.com/albums/s211/jlatenight/deinterlace.jpg
When I convert the .tivo to .mpg, WMP uses the same video decoder, "ffdshow mpeg-4 video decoder". Can I configure ffdshow to deinterlace, or is there a better decoder I should be using that can deinterlace on the fly and is compatible with Tivo2Go?
Thanks for the reply gunslinger!! I installed VLC and it plays tivotogo files that I have converted to .mpg WAY better than WMP. Let me ask you this: can you somehow configure VLC to play tivotogo files "*.tivo" files? I try to play them and it's just black screen with no audio. I didn't have much luck finding something on my own. Any ideas?
Mpeg4 in WMP11
By Beaker14 in forum AudioReplies: 13Last Post: 5th Jul 2012, 18:10 -
Cannot play AVI on WMP11
By jonghyunchung in forum Software PlayingReplies: 1Last Post: 19th Jun 2009, 06:54 -
WMP11 Parental Control
By jonghyunchung in forum Software PlayingReplies: 2Last Post: 4th Jun 2009, 13:55 -
WMP11 can't play .asf?
By ChiSholm in forum Software PlayingReplies: 2Last Post: 8th Jan 2009, 07:19 -
MP4 in WMP11
By neljan in forum Software PlayingReplies: 7Last Post: 2nd Feb 2008, 00:51
