Ok heres the scoop,I have two dvd players and one is a all region that dont like to play dvdr's so I have to play my burnt movies on my region one dvd player.I have pal vob files that I would like to convert to ntsc so I could play them on my dvd player.I need a free converter that doesnt leave a water mark.I normally use ConvertX2dvd and that works for converting avi's to vob pal to ntsc and vice versa but it wont let me convert vob files.Any help would be appreciated.
Sean
convert it to an mpg file
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Would I lose any picture quality? and would I have to do anything to keep the audio?
Sure it does.... i just did 4 PAL dvd's to NTSC dvd's this week by just ripping the disc, dropping it onto ConvertXtoDvd v2.2.3 and burning the resulting folder, but you lose the menu's unless you make new ones in the program.Originally Posted by mmmipa
What is best way to convert vob files from pal to ntsc and vice versa?
By hibbs in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2010, 19:41 -
authoring PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB files
By ah76 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Oct 2009, 09:31 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 09:11 -
Convert NTSC VOB --> PAL VOB
By djdust in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2007, 11:29
