I read that files converted to 720 x 576 (2703kbps bitrate) AVI look great on the Archos 704. What is a good program (free) for converting VOB, MPEG2 and wmv files to this?
Results 1 to 11 of 11
Does AutoGK have 2 pass cabability? I didn't notice it. Can you specify the bit rate for video? Again, I didn't see it.
AutoGK does 2 pass by default unless you choose to do a CQ encode. You do this by setting a Target Percentage on the main page, instead of a size value. Target percentage (Constant Quality) encoding is a single pass encoding with limited control over bitrate or file size.
You set a bitrate by defining a target size. Size = running time x bitrate, so use a bitrate calculator (I like vcalc) to work out what size you need to reach to get your bitrate.Read my blog here.
And it won't accept WMV. Here's what it will accept:
http://www.autogk.me.uk/modules.php?name=TutorialEN#5IFO file is used when you have a DVD like directory that contains IFO file and corresponding VOB files. IFO file is parsed and choice of audio streams and subtitles is presented to the user. If IFO file contains multiple PGCs (program chains) or angles then user will be asked to confirm which ones contained in the vobset (unless the name of VOB file contain this information already). Note that AutoGK cannot work properly on a vobset that still has multiple angles/program chains, so make sure to use appropriate tools to prepare the vobset. Another thing to remember is that AutoGK only works on unencrypted VOB files.
MPG, MPEG, VOB, VRO, M2V, M1V, DAT files are expected to have MPEG1/MPEG2 video inside. Only information about audio type (but not language in case of VOBs) is available for these types of files.
TS, TP, TRP, M2T files are expected to be transport streams with MPEG2 video inside. If it has multiple video streams then you'll be asked to confirm which stream AutoGK will be working with.
AVI files can have potentially any type of video inside (including DivX/XviD and DV sources). Main requirement for AutoGK to be able to process them is that they can be played in Windows Media Player (or any other DirectShow-based player) on your Windows installation. For current limitations and features see latest FAQ on AutoGK's web site -
Any reason you want to convert to a very low (comparatively) bitrate for the screen size ? BTW, AVI is only a container, what format are you actually converting to within that container for your video and audio ? Xvid/mp3 ?
The Archos 704 needs Xvid or Divx unless I purchase a plugin. I am also hoping to reduce the file size somewhat (2x or so) for more storage, but would like to have good qaulity. The file system is fat32, so there is a limit on maximum file size.
Are there other tools worth considering besides AutoGK? -
OK. Your video is xvid ... your audio ?
You have competing needs ... storage (long term storage?) vs playability. Your choice. Fat32 = 2Gb limit I seem to recall. -
Use VirtualDub, Xvid codec, 2 pass, Lame MP3 at 128Kb CBR. AutoGK can also do this, but in my experience, it compresses to a less sharp/more pixellated look in Xvid. Xvid files are approximately 1/2 the size of the Divx 4.0 files that the rather excellent Archos 704 produces on the fly. I often VDub my Divx 4.0 files to Xvid (takes about 2 hours per 2 hour Divx file), and of course, your 80Gb HDD likes the smaller filesizes! You can cram more in.
What's the best way to Convert 704 to 720? Avisynth or otherwise
By VideoFanatic in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2011, 03:19 -
720 x 576 question
By higgins327 in forum Newbie / General discussionsReplies: 24Last Post: 31st Mar 2011, 15:44 -
704 x 576 Resolution in Premiere
By Haz567_a in forum EditingReplies: 5Last Post: 23rd Jul 2008, 06:01 -
dvd plays at 720 x 576 but when ripped goes to 352 x 576 and is squashed
By aljolson in forum Newbie / General discussionsReplies: 12Last Post: 8th Jun 2008, 12:54 -
704 vs. 720 burn to DVD
By brstephe in forum Authoring (DVD)Replies: 20Last Post: 11th Dec 2007, 13:16
