  1. Member KeepItSimple's Avatar
    Apr 2005
    Sacramento, Kahleefornya
    Hello I've used ffmpegX zillions of times successfully. Now when I try to encode a file I get a "Choose Application" box that comes up and the question "Where is Progress.app?" is in the box.
    I re-downloaded and re-installed everything including the binaries but still get the Choose Application box when I click encode. Does anyone know what the problem can be?
    Thanks.
    Oh BTW it's ffmpegX version 0.0.9y and I'm running OSX 10.4.11 .
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    If you would have looked in the appropriate forum, then you would have found that a few others reported the same thing and a solution has been found.
  3. Member KeepItSimple's Avatar
    Apr 2005
    Tanks
