Results 1 to 9 of 9
    Jul 2007
    Howdy :
    Have a Video_TS folder with VOB files - play great in VLC - good picture and great sound
    stream 1 is audio dtc codec
    when placed in Toast 7 - no audio records - even with Perian
    anyone have a clue and care to share
    Cheers in advance
    Dec 2003
    Eugene, Oregon
    What setting are you using in Toast? Are you trying to burn it to a video DVD?
    You can choose DVD-Rom (UDF) as the format in the Toast Data window, click New Disc and add the content from your VIDEO_TS folder. Give that a try.
    Jul 2007
    Howdy Frobozz:
    I am burning Video - DVD Video - from Video_TS ---- Toast Titanium 7
    UDF would only give me a data file -
    Dec 2003
    Eugene, Oregon
    Originally Posted by BattyRoy
    Howdy Frobozz:
    Not so. If you have a valid VIDEO_TS folder then you can use the DVD-Rom (UDF) setting in the Data window. This also is a great way for adding other content to a disc along with the VIDEO_TS. The result will play in DVD players.
    Roxio added the DVD video from VIDEO_TS option in the Video window because users expect that's where they need to be to burn video DVDs. But it works in the Data window and there's no chance of Toast changing any of the content.
    Jul 2007
    Howdy Frobozz:
    tried it your way - burned fine fine - no audio still
    plays no problem in VLC with great audio
    any more suggestions ?
    cheers ya
    Dec 2003
    Eugene, Oregon
    What are you playing this in that doesn't play the audio? Is it the Mac, your standalone DVD player or both? Using your standalone DVD player what happens when you use the Audio button to access the different audio streams? Or did this VIDEO_TS folder have the AC-3 audio stream deleted so there is only the DTS stream? As you can read in the What is DVD here at videohelp.com one track must be DD or PCM on a video DVD. The DTS stream can't be the only audio.
    Jul 2007
    howdy Frobozz:
    I can only play on Mac DVD player after burned
    The VOB files have a VLC icon - when played in VLC I get audio - stream 0 MPGV
    stream 1 dts audio
    When put in Toast - shows video file but audio file 0
    if dts is embedded in video files - anything I can do to get this to burn with audio with Toast
    Cheers for your assistance and time :
    Dec 2003
    Eugene, Oregon
    There needs to be either an AC-3 or PCM audio track multiplexed with the Video somewhere. But I'm guessing from your description that it is missing. You probably know that some DVD players cannot play DTS and that it requires connection to a DTS-equipped AV receiver in order to play DTS audio. So it is possible this isn't a Toast issue but either a problem with the VIDEO_TS folder or your playback hardware.
    When Toast burns a VIDEO_TS folder it neither adds nor removes anything unless you use the DVD Video from VIDEO_TS setting and click the Options button to select specific titles and/or audio tracks. You cannot, however, select only a DTS track as I've mentioned before. What happened to the Dolby Digital AC-3 or PCM audio track? If neither is present then you don't have a valid VIDEO_TS folder and I don't know any way to make a video DVD that has only a DTS track that will play on a standalone DVD player with audio. I'm also not aware of how to export a DTS track into a different format so it can become an AC-3 or PCM track in a newly authored VIDEO_TS folder.
    Do you have MPEG Streamclip? If so, open the title set from the VIDEO_TS in Streamclip and read the description of the audio and video streams. What does it say?
    Jul 2007
    Howdy Frobozz:
    Path: ~TOR 3 The Mach/VIDEO_TS/VTS_01_1.VOB
    Type: VOB program stream
    Duration: 1:44:39
    Data Size: 4.36 GB
    Bit Rate: 5.96 Mbps
    Video Tracks:
    224 MPEG-2, 720 × 576, 16:9, 25 fps, 9.80 Mbps, upper field first
    Audio Tracks:
    137 AC3 1+1, 48 kHz, 32 kbps
    Stream Files:
    VTS_01_1.VOB (1024.00 MB)
    VTS_01_2.VOB (1024.00 MB)
    VTS_01_3.VOB (1024.00 MB)
    VTS_01_4.VOB (1024.00 MB)
    VTS_01_5.VOB (367.87 MB)
    not too familiar with MPEG Slipstream - but when files are placed and opened - i get no audio or video - Only have the free version - does this make a difference?
    Cheers again for your time and efforts:
