I have a number amount of small quicktime .mov files and I want to combine them as one so it can be like one big movie.How can i do this?
They have to be the same specifications (same size dimensions), otherwise will have to be re-encoded
Try MPEG streamclip with the quicktime alternative plugin -
copy file #1 with control+c (or edit=>copy), control+v (or edit=>paste) into the second file. If you want to edit segments just use mark in/mark out
Then file=> export to quicktime (or some other format if you want)
I'm assuming you already set it up correctly (quicktime alternative); if you don't know how, go to the author's webpage and there are instructions there
Cheers
EDIT: if they are the same specs, an alternative would be to join them in YAMB
Free Software to combine old QuickTime files?
By videonewbie22 in forum EditingReplies: 5Last Post: 1st Sep 2011, 21:35 -
Need to combine .mpg files to one (What to use)
By neworldman in forum EditingReplies: 5Last Post: 26th Jan 2011, 18:23 -
How would I combine 2 avi files into one?
By Variable in forum Newbie / General discussionsReplies: 7Last Post: 27th Sep 2010, 17:50 -
Can I combine two VIDEO_TS files?
By Levina in forum MacReplies: 14Last Post: 17th Mar 2008, 19:51 -
How do you combine .vob files?
By xoADAMox in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2007, 02:04
