Hi,
I have a bunch of AVIs (of various lengths/sizes) that I need to re-encode so that they take up less space. The after-size of any individual video doesn’t matter, as long as the total size of the post-processed videos fits the target (although I would like them all to be of relatively equal quality).
What is the best/easiest way to do that?
Also, after they have all been shrunk, I need to join each one to another video. The original video has the same properties (size, frame-rate etc.), but obviously would have a different (higher) bitrate since I am shrinking these ones. Is that possible? Can you join two videos of differing bitrates?
Thanks a lot.
Yes you can append 2 different bitrate videos, but the dimensions have to be the same
I would open them up in order that you want in avidemux. Append the next one, the next one, so forth
At the bottom you will see the accumlated running time, increasing as you add each video
When you are done adding, select your video codec in the left sidebar (like xvid), but leave the "configure" option for now. You can add some filters if you want.
Select your audio codec (like mp3), configure your bitrate, filters etc..
Enter your format container (like avi)
Push the calculator button, enter the final size (its a bitrate calculator) and it pretty much figures it out for you, press apply. Now if you double check the video configure button, you will have noticed the bitrate changed to whatever the calculator figured out.
Press save with extension (e.g. "myfile.avi")
There is less room for error when you simplify the process all in 1 step instead of shrinking each one some predetermined amount then appending them
Cheers
Avidemux Target Size Problems
By FrozenInferno in forum Video ConversionReplies: 10Last Post: 2nd Apr 2011, 15:52 -
shrinking the size of a video
By m005k in forum Video ConversionReplies: 2Last Post: 3rd Jun 2010, 15:35 -
convertxtodvd target size problem.
By kuzutolga in forum Video ConversionReplies: 8Last Post: 2nd Nov 2009, 17:18 -
xvid target size problems
By Cowabunga in forum Video ConversionReplies: 13Last Post: 16th Jan 2009, 16:11 -
video size keeps shrinking
By gally56 in forum Authoring (DVD)Replies: 1Last Post: 15th Apr 2008, 09:01
