Results 1 to 9 of 9
Are you looking to do just a quick avi to DVD, or a full DVD production with making menus, editing footage, ect?
I will use DVD lab pro when I have my material ready. Only chapters and a couple of menus with a couple of subtitle tracks.
You can get quality as good as , if not better than cce, by using the freeware HCenc to encode your video.
Encode your audio with aften then author with software like guifordvdauthor.
If you just want quick and easy with simple no frills menus then you can use an all-in-one like favc to automate the process for you.Donadagohvi (Cherokee for "Until we meet again") -
Try what freebird said... I use Sony Vegas/DVD architech for all my stuff, and they kind of go hand in hand are have probably way more options and will probably be un-needed for you if your only doing smaller quick dvds.
Where does Canopus ProCoder stand? I don't mind if it will consume a lot of time or if it's fast, complex or simple. What I want is the highest possible quality. I haven't been much into video editing for the last couple years, so I thought I 'd ask whether CCE is still the best. I already have CCE 2.7 so if there are no significantly better options, I will go with that.
What I do with my stuff is capture the footage with Sony Vegas, make all the edits I need (wicth if your using DV from a camcorder it will be captured as an avi file), and then render it with Vegas. The neat thing about Sony Vegas is that the DVD architech program is also from Sony, so they go hand in hand.
There are rendering options in Vegas. You render the video and audio seperatly. Audio takes very little time, but video it depends on your pc power.
It will render the avi file in an mpeg2 dvd format, and the best option in Vegas for dvd audio is rendering in Dolby Digital AC-3. Depending on the setup in Vegas, you can get either surround sound or stero.
Its all production software, so you get the full package... -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
VHS/ DVD Go-Video problem. Bad video, good audio
By Shempp Ranger in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 20:31 -
Suggestions on Good Flash Encoders (free?)
By Mekamur in forum Video Streaming DownloadingReplies: 4Last Post: 14th Jan 2009, 15:33 -
encoders?
By just in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2008, 09:15 -
Video Quality from different encoders--Vegas, Nero, Pinnacle, Ulead, Encore
By sir_rob in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2008, 11:32
