Results 1 to 18 of 18
  1. http://www.varizoom.com/products/tripods/vz-tk75a.html
    I'm currently looking at this tripod. Anyone ever used one like this before? Any dirt against VariZoom Tripods?
    Thanks for your input.
    breaking news is my life...
  2. Member Soopafresh's Avatar
    Jan 2004
    That's a good one.
  3. Member zoobie's Avatar
    Feb 2005
    Florida
    ok for a little travel tripod only
    6.5 lbs isn't enough...wind will shake it, etc...
    May 2007
    reality
    What camera(s)? What will you be using it for - studio, field, travel? Doing alot of panning?
    Apr 2006
    Grenada
    how heavy is the camera you are going to use?
    how high do you want the camera to go?
    Bogen Manfrotto is a good brand but pricey
    How's My English?
    Apr 2006
    Grenada
    oh ok my bad
    i didn't see that you responded. That tripod looks good; however, as Video Head stated, what type of work are you going to be doing?
    I would look for a tripod that at least have the rubber soles.
    How's My English?
    May 2007
    reality
    I agree, Bogen is very good and worth the investment if this is your vocation.
  8. Thank you for all your replys.
    I shoot with a Panasonic DVX-100A. I do a lot of corporate, commercial, web video work. I currently have a Vinten Vision 5 tripod, but I'm missing the plate. I was thinking of getting this pod, and if the legs sucked, just replacing the head onto my Vinten pod.
    As a experienced shooter, I've learned not to step away for a pod with a camera on it. I've learned that the hard way. Maybe you all have some suggestions of pods I should look at. I do like the Bogen pods, not sure what model to get. I'm trying to stay under $250...that's my budget...I wish I could spend more.
    Thanks in advance.
  9. 4.034 lb (1.83 kg) with battery and cassette
  10. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    I'd spend the money on a refurb of that Vinten. They are the RollsRoyce of camera support.
    http://www.kiva.org/about
    May 2007
    reality
    Thanks in advance.
    As an experienced shooter you should have known to tell the whole story, the whole story and nothing but the whole story the first time round...nothing like a second take to keep everyone happy...
  12. with the plate in the ebay pic...is it capable of putting a 1/8 inch screw in there to mount to my camera?
    that is the whole story. thanks
  13. Member olyteddy's Avatar
    Dec 2005
    1/8 inch? Are you sure it's not 1/4 X 20 thread? (most cameras are)...
  14. ok. yeah i think it is the 1/4" x 20. so it should be golden then?
  15. Member zoobie's Avatar
    Feb 2005
    Florida
    ...and repairing it is mine
