I have some VOB files sitting around my imac. I want to convert it into an ISO file, so I can burn it onto a RW DVD with all the bells and whistle of a regular DVD.
Thanks for your time.
You need an authoring program like Toast.
If the vob files are standard, iDVD can't use them, though you can use mpeg streamclip to convert them to useable formats (a search here should get you some tutorials). -
I forgot to mention that the VOB files already have DVD structure when it was ripped from the DVD. What I was trying to ask but probably came out wrong was how to convert those VOB files into an ISO file so I can burn it to a blank DVD with Disk Utility.
Try DVD Image Utility. Simply drop the DVD folder onto DVD Image Utility and it creates the DVD image file. Then drop the image file onto its icon to then burn it to blank media.
Thanks Case and ArtemisG3. You guys are a life-saver.
I did have a problem with DVD Imager in the beginning. It would just say "Working" and never finish or start for that matter.
It hit me a couple of minutes later that it might be the name I gave it (similar to the quirk in Simple DVD). I used the default name and sure enough it worked.
The program should display an error message if we aren't using the right naming format. :P
It can take a while to make the image. You could always get info on the destination file in the Finder to see if it is "growing".
Yeah, thanks.
I got it working. It was the naming problem that made it freeze on "Working". After I used the default name, it immediately showed a progress bar that was missing earlier. You posted before I finished editing my earlier post. I didn't want to double post so I just edited my post.
Help me create an .iso file from .vob dvd files!!
By SlyOne in forum DVD RippingReplies: 2Last Post: 15th Aug 2010, 10:25 -
How do I convert VIDEO_TS containing VOB, BUP, IFO files to a single file
By Firesmith in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2010, 12:14 -
Convert ISO to VOB
By larrytxeast in forum Video ConversionReplies: 6Last Post: 23rd Jul 2010, 01:20 -
Help with .vob and .iso convert? [not sure which forum]
By Penguinish in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2009, 14:08 -
convert iso file back to vob file
By cda62 in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2008, 13:50
