  1. Hi,
    How to I convert cds or vcds to vhs? Any help would be appreciated.
    Angie
  2. Depends on your hardware.
    If you have a graphics card with tv-out, connect this to your vcr with an rca(phono) lead.
    if not , consider an upgrade to a video card that has this or buy a scan converter.
    Look in the 'how-to' section on this site on viewing stuff from computer on tv's, but connect to your vcr instead of your tv.
    Obvious really!!!
  3. Thanks! I have a video caption device that I have a cable where I connect it to the computer and the vcr. But it didn't work. When I put the vcd in I thought that it would automatically come up on the tv.
    Angie
  4. Hi angie,
    i think you mean video CAPTURE devise. If this assumption is correct then this is probably a so called tv card. It has two main uses
    1- to enable you to watch tv programs on your computer monitor just like your tv. To do this you just plug in a tv aerial (antenna) just like with a regular tv into the socket on the back of the computer marked ANT (the tv aerial will only fit in the correct one anyway)
    2 - to record (capture) vhs tapes from your vcr into your computer, using the leads i think you described.
    NOTE -- both of these functions of your tv card involve getting stuff INTO the computer. The tv card cannot output stuff to a tv or vcr, which is what you requested originally ( vcd/cd to vhs TAPE)
    Look at the green sections on the left (the 'how to's ) and select PLAY.
    then look towards the bottom of that page and read the 'how to watch contents of your computer on a tv'. Substitue tv for vcr and bobs your dads brother!
    Good luck, scott
