Hello
I need to create very long motion menu, e.g. 3600 sec.
How many seconds can it take?
What is the limitation?
Results 1 to 14 of 14
Time in motion menu is secondary. The menu (all together, if more than one) can only be 1GB size in one VTS so you have to figure out a bit rate to fit.
For one hour it will be really low with bad picture. -
It does not matter where you do it.
Render Menu is meant to include buttons in motion menu, otherwise they will not show on compiled DVD.
If you try to render 3600 sec, with 8000kbs/s default, it is too much. You can set bit rate in there, but you have to know what it is.
Using bit rate calculator, it should be in range of 500-600kbs/s, less with linear PCM audio. -
Will there be buttons on the menu?
You could try using a Title, and adding ButtonsOverVideo (BOV)
Regards,
George -
Ther is a help manual for download on DVDLab (Mediachance) web site.
It explain BOV (Buttons Over Video) and other thinks you can do with DVDLab Pro. -
Have you ever seen the DVD of The Matrix. It has a feature called Follow The White Rabbit. At different point in the movie a white rabbit appears on the screen. If, during these times, you press Enter on your remote, you branch off, watch some behind the scenes footage about the scene, then return to the movie. The rabbit is done using BOV.
Read my blog here.
I can't, for the life of me, figure out what you're going to do with a motion menu that's an hour long.
I have to create (author) DVD9 but I have only 3,3GB movie size (3x25min) - don't ask me why DVD9
I have to increase size of VOB material. I've inventioned MotionMenu (1GB) or additional movie with BOV.
I tested BOV, and everything is OK but during plaing movie, if I increase speed e.g. 2x then "Play movie" - my button disappear. -
A p0rn slideshow-video would be an option much-more usefull/interesting IMHO.I have to create (author) DVD9 but I have only 3,3GB movie size (3x25min) - don't ask me why DVD9
there's no rhyme or reason to a lot of these questionsOriginally Posted by dadrab
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Is it possible to extract the video from a motion menu?
By mjvgiese in forum DVD RippingReplies: 2Last Post: 3rd Dec 2007, 21:31 -
Editing Motion DVD Menu
By gallardo in forum Authoring (DVD)Replies: 5Last Post: 6th Nov 2007, 21:12
