  1. Check out this subtitle searchengine I am using it now for a week and I could find all the subtitles on demand.
    SubtitleDB search engine
    Croatia
    Useless bull***t.
    Points out to allsubs.org and mysubtitles.com with hundreds of false findings.
  3. You can also state it like this: hi acid_burn, if I were you I will delete the following sites: allsubs.org and mysubtitles.com. Because they are pointing to false findings.
    Thanks for your suggestions :( :wink:
  4. opensubtitles.org & subscene.com are nice.
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    It's just a custom Google search. You can Google for
    "subtitle moviename" and get pretty much the same mishmash.
    Which I do sometimes if the usual sources, like opensubtitles.org fail.
    But only as a last resort.
    Croatia
    For the moment, the only good, no spam, no bull, positive results only, subtitle search engine is:
    http://www.all4divx.com/
    It covers all major subtitle sites in most languages.
    The results pop-out in less than a second and if a subtitle for a certain movie has been uploaded to the net, it will be there.
    Nov 2007
    Argentina
    Why don't you try SubtitleSync.com.ar?
    It has a small DB but it really fast to use!!!
    Also it has subtitles in other languages. You have to go to the advanced search and select the language.
    The really good thing about this site is that you can also search by the number of parts of the video you have.
  8. I Know a site that counts how many times a Subtitle have been searched at the web. Check this out!
    subsearches.com or click here http://www.subsearches.com
    Ouaoooo!!!
