I tried the latest vso ConvertxtoDVD 3.0.0.9 and I found that it has a problem. It doesn't convert dts to dts, but to AC3. If it's dts 6.1 and encodes it as dca 5.1. My dvd player doesn't show the dts sign as soon as it reads the dvd like it does on all the other dts dvds. What do you think about this problem? Thanks for helping out.
Crazy about movies
But the previous convertdtodvd versions did it. Its v3.0.0.9 that isn't doing it.
Crazy about movies -
The real answer would have to come from VSO software (makers of ConvertX2DVD). If you need DTS, simply switch back to an older version until it is fixed.
Google is your Friend -
The problem with previous versions, am talking here about 2.9... onwards before version 3, is that certain mkv files, like aeon flux and Die Hard 4, to give an example, are converted with some buggs, stop and go movie, slow to fast. Bugs like that. V3.009 takes care of these bugs, but the audio is transcoded to ac3 instead of dts.
Crazy about movies
ConvertXtoDVD Problem
By natty in forum Newbie / General discussionsReplies: 24Last Post: 17th Feb 2010, 21:06 -
By natty in forum Newbie / General discussionsReplies: 3Last Post: 1st Aug 2009, 14:21 -
Convertxtodvd problem.
By lameyouth in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 15:38 -
No Audio Stream in ConvertXtoDVD (AAC Audio)
By incrediblej in forum Video ConversionReplies: 2Last Post: 18th Sep 2008, 20:31 -
Problem with convertxtodvd
By extreme1000 in forum Video ConversionReplies: 1Last Post: 30th Jun 2008, 22:21
