I am converting an H.264 mkv to avi with Alltoavi. It tells me to switch to RESTRICTED MODE when I add the .mkv to the list. I have tried every setting, but the audio is always ahead of the video on the outputted .avi.
Once you have the avi, open it in Media Player Classic, and use the + and - keys on the numpad to sync up the audio. Once you have the audio in sync, look at the delay (at the bottom of the status bar) and write it down.
Now open the video AVI Demux. Leave Video and Audio set to Copy, tick Shift, and put the delay number into the field. Save a new version of the file and test to see if the problem is fixed.Read my blog here.
Ok. I'm trying to add the .srt subtitles now with virtualdub, but it says:
Code:[!] AVI: Variable bitrate (VBR) audio detected. VBR audio in AVI is non-standard and you may encounter sync errors up to 3531ms when attempting to extract WAV files or processing the audio in Direct Stream Copy mode. Full Processing mode is recommended to decompress or recompress the audio. (bitrate: 130.1 ± 20.9 kbps) -
Again, try AVI Demux. It will build a VBR map that avoids any shifting. You can then use any of the subtitle Video Filters to add your subs (including a version of VobSub).
AVI Demux has replaced Virtualdub for most bread and butter work on my system. I still use Vdub for specialist filters, but for basic fixes, joining etc, AVI Demux is so much easier.Read my blog here.
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 15:22 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 10:31 -
lagarith avi to xvid avi - problem
By phpmysql348 in forum EditingReplies: 1Last Post: 23rd May 2008, 12:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
