Hi, after making multiple searches, i'm just a little more confused... I recorded a video from a mini DV (borrowed), then I put it on a DVD (with DVD recorder). I converted it to a mpeg file and since DVD movie Factory seemed to be the best bet (because i want to add a slideshow), i tried it but audio format is not supported (i think it is AC3 from the mpeg file)
What would you suggest as a program or converter, please heelp!!!
Thanks a lot
I did not work from VOB files. DVD has been converted to mpeg from ShowBiz DVD, it plays fine on WMP and DVD factory's Player.
When file is inserted to create, DVD MF says "contains Dolby Digital audio tracks. DVD MovieFactory does not support this audio format. Do you still want to insert this video clip?". I demuxed the mpeg file, audio is AC3.
Now what?
The thing is that i edited a full movie (w/deleted sequences) so I would like to work from this Mpeg file... What would you suggest?
Thanks for your reply!
Add audio won't work in audio menu.
By petwes in forum AudioReplies: 0Last Post: 21st Jan 2012, 08:59 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 18:27 -
.ts audio not work
By elmc in forum Video ConversionReplies: 1Last Post: 3rd Aug 2008, 16:39 -
My audio cd did not work???
By championjosh in forum MediaReplies: 3Last Post: 27th Dec 2007, 08:32
