I need to keep a website that has some photos between 50k and 150k.....what sort of image compression is best for the web?
Jpeg or Gif and are there specific settings to utilise for the web? They will not be full size obviously but around 300px x 300px
I will use photoshop.
I am not sure about a specific software, but I normally use Irfanview when I wish to upload a picture. You could also use the same trick used by web stores, upload a small picture and link it to another with best quality, in case a visitor wishes to see more details, he will have to load it in a different window.
No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. .. -
g'day Rudyard!
There are some possibly non-obvious considerations...
Gifs are only 256 colors (as I assume you know) so be sure to create archives of both your fullsize full color originals and the uploaded versions.
JPGs are usually close to GIFs in size; the main use these days of GIFs is animated banners, or page design elements like buttons.
You might want to consider that your pix can be pirated too, that might effect sizes used, compression, and you can also watermark them.
My best advice is to throw some or your best & worst pix onto a private web page, and then view them from a variety of friend's computers.
Have fun!
Video compression error: The source image format is not acceptable
By jh443 in forum Video ConversionReplies: 8Last Post: 25th Apr 2011, 22:56 -
video compression error: The source image format is not acceptable.
By cutepraba in forum Video ConversionReplies: 0Last Post: 12th Dec 2010, 11:21 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
best compression for image sequence movie ??
By mehdi0016 in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2007, 10:17 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
