I have a dvd that I've made, with a nice menu and everything just how I'd like it. I would like to add music to the menu.
Is this possible? If so, what programs can do this?
I've been digging thru DVDRemake to see if it can, but it looks like I'd have to re-make the menu and I'd like to avoid that if possible, especialy as I'd still need an author program that can do music in the first place. (I used Roxio Toast to make the DVD, then Remake to customize the commands).
So to sum up, PC or Mac. Would like to edit/add to prexisiting menu, unless there's something that extract the menu add the music and then return the menu.
Closed Thread
At the very least you will have to demux the menu video, add the audio, then put it back. If the menu you created was a still image, you will have to remake the menu.
Read my blog here.
Scav2003, Do not post the same topic on several forums.
Please do not cross post, once is enough. If you want a topic moved to another forum, PM a Mod.
Continue in: https://forum.videohelp.com/topic348885.html#1833289
Moderator redwudz
idx/sub/sup problem when to be added to dvd
By StarX in forum SubtitleReplies: 4Last Post: 19th Jan 2009, 23:34 -
Multiple Audio Titles With DVD Menus
By GiLGiJ in forum Newbie / General discussionsReplies: 1Last Post: 18th Apr 2008, 14:17 -
How to adjust the audio to be all the same in every video file added todvd?
By f-zer0 in forum AudioReplies: 5Last Post: 27th Feb 2008, 18:01 -
Audio CD with an avi file added
By Sskafar in forum AudioReplies: 3Last Post: 17th Dec 2007, 21:19 -
editing DVD audio without breaking menus
By nbi in forum Authoring (DVD)Replies: 9Last Post: 10th Aug 2007, 14:02
