[quote="edDV"]Agreed on using the monitor. The only way I have ever been able to set mine up is to have it connected to the TV and a monitor at the same time. The chances of just connecting it to the TV and having it work are slim to none. I have now set up my HTPC to have remote administration from another workstation over the network. Much easier than lugging a monitor and connecting it every time you want to change something - also keeps the wife from asking what's wrong with that thing now.Originally Posted by FoilBut words of advise: once it is working the way you want, leave it alone...I have had to start over again a few times due to a "tweak".
Once you are running you should be able to create custom profiles in Catalyst Control Center. I set-up 2 profiles for myself. One overscans for video playback and one just underscans for desktop. I have keyboard hotkeys set-up to toggle between the two.
Results 31 to 41 of 41
LOLOriginally Posted by Video HeadRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I guess my expectations were wrong, then. I expected it to work "from the get-go", as it did when I had the 8800.Originally Posted by Video Head
I'll try it with the monitor tonight. -
One day they will invent Viagra for computers...no really, they will...Originally Posted by edDV
It goes that way with the ATI cards. But if you stick it out and overcome you will be very pleased. This thread may shed some light on what is required in terms of tenacity:Originally Posted by Foil
https://forum.videohelp.com/topic344948.html -
Hi,
I am with the other posters who suggested setting up the display using another monitor. I would suggest you connect to the VGA input on your TV and the HDMI. Then you can switch to the VGA display, and then set up a dual monitor display in software preferences, selecting clone mode, the switch back and forth between both inputs on your TV remote, making sure you have the correct settings for each display that works best.
Cheers
adcvideo -
Well, I tried hooking up both the monitor (via the VGA on the x850XT) and the TV (via the DVI-to-HDMI), and got mixed results. At 1920x1080@60Hz, I get nothing on the TV, but it does work at 1920x1080@30Hz (TV indicates a 1080i signal).
However, when I try to switch to the TV as my primary monitor, I get nothing. Same result when I then tried to reboot and have only the TV connected.
I'm gonna try that DIN-to-component connection next, I'll keep you posted. -
Well, the DIN-to-component connection worked @ 1920x1080@30Hz. I guess I'll use that until I can get something like an 8600GT card in the machine.
Again, thanks for all the help, guys. -
Good luck, Im running an 8600 gts, fantastic picture off it ive stopped using my dvd with upscaler, as i get a better picture. but never use it above 1280 720 as i find it way to small, for viewing as computer screen
Glad to hear it works...don't give up on the DVI out as it may just be a setting.
Thanks. I haven't given up on the DVI out, but it's on the back burner now, as a new problem with a wireless PCI network card cropped up (ten feet downstairs from the router, it won't connect). :P
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 01:15 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 5th Aug 2009, 00:14
