Hi,
I recently rebuilt one of my machines to be a media center and I am trying to connect it to my Panasonic 1080p HDTV using a DVI-to-HDMI cable, but I'm having a problem getting it to work (black screen on TV, indicator shows no signal).
Here's the thing, I hooked this same machine up just a couple of weeks ago, using the same cable, and had no problems getting it to run at 1920x1080. The only thing I've changed is the video card; I switched the 8800 I was previously using (which went to another machine) for a working x850XT.
I know the DVI output on the x850XT is fine, because it hooks up to my monitor upstairs via DVI-to-VGA and works correctly. I have all the correct drivers, the BIOS settings are the same, and the cable is okay, but I don't get a signal at all while it's connected to the TV. It has me stumped.
...Any suggestions?
Results 1 to 30 of 41
the card is too old. it doesn't support hdcp so the best it would hook up at is probably 720.
big brother doesn't want any chance of HD signals being copied.
http://en.wikipedia.org/wiki/HDCP--
Thanks for the link; I fully understand why it would be a problem for an HDCP signal to be displayed on a non-HDCP display.
But that isn't the case here, it's the other way around. The display (my new HDTV) supports HDCP if needed, but the source signal from my x850XT doesn't even use it. Why would that be a problem?
[Edit: The problem is not that I can't play HDCP content, it's that I can't even get a signal at this point.] -
can you try it at 720 60Hz?
Originally Posted by Foil
Are there any settings to switch the DVI output from analog to digital out? -
Originally Posted by aedipuss
If I could get to the graphics settings, of course I'd try all the available resolutions and refresh rates.
However, as I've said at least twice now, I can't get anything on the HDTV. No boot screen, no BIOS setup, no OS, nothing. So there's no way for me to try to adjust resolutions and refresh rates at all. -
Originally Posted by Megahurts
I'll take a look and see what I can find.
[Edit: I just verified that the x850XT's DVI is "DVI-I" (supports the four analog pins). The DVI-to-HDMI cable doesn't have those pins, so it looks like you're probably correct. Heck, maybe it's a jumper on the card or something. Thanks for the tip!] -
Well, I couldn't find any digital/analog settings, at least in the mb-BIOS or any jumpers or such on the card itself. Any other ideas, guys?
I did find an SVideo-to-component(YPrPb) adapter that came with the card, but I haven't tried it yet. Any idea if that could carry a full 1080p signal?
Thanks in advance for your help! -
Your Panasonic 1080p HDTV should list the resolutions and frame rates accepted in the manual or at the support web site. There will be separate lists for the HDMI and VGA inputs. The VGA inputs are usually a no-brainer and result in an image with no overscan. This is particularly useful for desktop or game display.
HDMI inputs nearly always overscan and usually accept a more restricted list of resolutions. In all cases 60Hz framerates should be used.
ATI cards of that vintage generally assumed analog component for HD connection. The card either came with an analog component cable or used an adapter connected to a DVI-I out. The card internally switched from VGA RGB mode to 1080i/720p/480p YPbPr when the adapter was used.
HD 1080p requires a top end card with good MPeg2 and/or MPeg4 decoding and heavy duty deinterlace performance for 480i/1080i source.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Hmm, thanks for the info.
I've been avoiding using the VGA input, as this model (PT-56LCZ70)happens to be limited to something like 1280x1024 using that input. I may end up doing that, though.
Otherwise, it looks like I'll need to use the SVideo-to-YPrPb adapter that came with the card (which seems to be the one intended for HDTV connections), although that means I'll have to switch things around because I'm already out of component inputs.
I'll post tomorrow when I can get back to this project.
Thanks again, guys! -
Originally Posted by edDV
Originally Posted by jagabo
(I'm aware I won't be able to play HDCP content with this card, but that's fine for now, since I won't be able to get a Blu-Ray drive for a while, either.) -
You still may be able to connect on the HDMI port if you use the resolutions specified in the TV manual.Recommends: Kiva.org - Loans that change lives.
What about going back to basics, bring your monitior down to your pc, tv. keep the hdmi plugged in and when it boots up on your monitor, make sure the desktop is cloned. it maybe just as simple that the default output is dvi.
Originally Posted by John
P.S. You guys have been extremely helpful, more than I expected. -
But there's no way for me to play with resolutions and refresh rates when I can't get it to connect in the first place. -
Originally Posted by Video Head
It didn't quite make sense to me that an S-video signal could be converted to component by a dongle, so that explains it.
That brings up a question for me, then: If I can get both the DVI and component outputs working, which one is preferable, from your experience? -
http://www.nvidia.com/page/purevideo_support.htmlRecommends: Kiva.org - Loans that change lives.
[quote="Foil"]
Is your goal to use the TV as your only monitor? In that case VGA without overscan makes more sense. HDMI and analog component will overscan.Recommends: Kiva.org - Loans that change lives.
DVI-HDMI generally has advantage at the cheap consumer level since analog requires expensive parts for highest quality. At the pro level analog component and SDI are common. DVI-HDMI are not used because they are limited to short cable lengths.
* If the connector only has 4 pins, it is an S-Video connector.Recommends: Kiva.org - Loans that change lives.
As I said before, the VGA for this TV model is limited to 1280x1024, so I'd prefer to go with the higher resolution from DVI/HDMI if I can. When I did this before with the 8800GTS card, I was able to adjust for the overscan.
My main question now is: assuming I can get both the DVI and component outputs working, which is best? -
Are you certain this TV is native 1080p? Samungs allow 1920x1080p over VGA. They also have a mode to defeat overscan on HDMI called "Just Scan".Recommends: Kiva.org - Loans that change lives.
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 00:15 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Aug 2009, 23:14
