I am using DVDFlick v1.2.2.1, I am adding 2 avi files to DVDFlick project. But the combined avi files are, Disc space used 4528MB of 4489MB, average bitrate 2810Kbit's and total duration 3:09:53hours. When I dreate DVD and use ImageBurn to burn the DVD(since DVDFlick does not recognize my internal burner), the last part of the 2nd avi file is corrupted. The movies paly until the last of 2nd avi (freezes up). I want to possibly cut out the credits or somehow shrink the avi files to fit on my DVDR. My burner is I/O Magic (external). Thanking you in advance, SY
	If your avi is corrupt then you can try repair it using divfix or similar tools(see our tools list) or cut it using virtualdub(click on it for guides).
 And lower the video bitrate to fit more/dvd. The source avi file size doesn't matter because they are reconverted to dvd-video when you use dvdflick.
	In the future, you can convert and burn files onto a DVD-RW disc. That way, if it doesn't work, you can simply erase and reburn. Once you have it working, you can simply copy the DVD-RW onto a regular DVD.
 And I agree, it sounds like a bad avi file or a file that your app is having issues converting.Google is your Friend
	glad you got it working
 I was about to ask why nobody commented on the fact that your finished DVD folder was larger than the available space
 that you needed to reduce the total file sizeDisc space used 4528MB of 4489MB,
  Captured AVI file too largeBy drgt in forum Newbie / General discussionsReplies: 38Last Post: 29th Sep 2010, 08:22
  Large corrupted AVI file, what to do?!By WaveofShadow in forum Software PlayingReplies: 12Last Post: 14th Sep 2010, 00:42
  ffmpeg choppy audio from large avi but not small avi source fileBy cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38
  Imported avi file from miniDV too largeBy prayami in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 14th Mar 2008, 06:25
  Avi file too large for CDBy hitmanhill in forum Newbie / General discussionsReplies: 17Last Post: 22nd Jan 2008, 15:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
