I'm using Vegas and I'd like to render a project into muliple wmv files (89 files to be exact). I can add markers or whatever to the start and stop for each clip.
what exactly are you doing?
is there audio that's going to be affected?
89 files?
select and copy a segment into a new project file and render
you may have to install windows encoder first before vegas -
OK, I have a project (.vf) that I have to chop up and create many .wmv files out of. Each .wmv file will end up being only 5-10 seconds long. I will later be transfering these files to .flv files for use in a flash game I'm having made.
I could set the loop region, render that loop region, then move the loop region but this will take quite a bit of time. Instead, I've set a marker between each clip and I was hoping that there was a way to render a different .wmv for each clip seperated by this marker.
As for the audio, yes, there is audio but it was captured and is I guess "attached" to the video. -
well, 89 files takes work
also, each time you re-encode, you'll lose some quality
try going directly from your source to flv
Vegas 8 vs Vegas 10 rendering MPG2
By schematic2 in forum EditingReplies: 0Last Post: 3rd Feb 2011, 14:32 -
Vegas 8.0 splits footage into multiple files!
By PapaDmitry in forum EditingReplies: 2Last Post: 4th Oct 2010, 17:33 -
Rendering .MTS files from my Canon HF-S100 in Vegas Pro 8.0 for youtube.
By fullerfour in forum Newbie / General discussionsReplies: 6Last Post: 24th Dec 2009, 00:05 -
How do you remove intro from multiple wmv files at once?
By scrambledeggs728 in forum Newbie / General discussionsReplies: 1Last Post: 9th Jun 2008, 02:49 -
Audio gaps in wmv files in Sony Vegas
By CompMike in forum EditingReplies: 4Last Post: 14th May 2007, 12:07
