  1. Banned
    Nov 2007
    India
    1)Go to "Add Printer Wizard" and enable/select "A network printer or printer attached to another computer" option.
    2)Go to "Printer And Faxes" option and right click then select "Sharing..." option.
    3)Then a window will open type name of your shared printer then click "OK"
    4)A window will get opened with a selected option then click on "Next".
    5)A browser window will get opened then click on the shared printer and press "Next".
    6)Then a window asking for "Apply" option will get opened
    click for applying the changes then click "OK" and then "Close" the windows that are opened.
    In this way you can connect or share you printer to local Computer.
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    You may want to have this moved to the Computer section.
    Also, you should specify that this is for Windows XP.
