I just bought speed grapher and was trying to RIP it to my PC but I'm getting some weird problems. I used "RipIt4Me" and had it RIP "Movie Only". It got all the files and said no File Structure and etc, it went normal. Then I joined the VOB's with "VOBMerge". Now I tested it like usual make sure I got everything with Nero Showtime. The whole DVD is skippy.. The video and audio is lagging skip fest..
I then ripped the whole DVD using "1 Click DVD Copy" and it plays fine, but I can't directly play the VOB's. So it seems as if it does have File Structure protection..
I did test this theory too by tacking the VOB's from "1 Click DVD Copy" and joining those, but got same results.. I'm stumped atm.. lol..
First DVD that has ever given me troubles..hmm..hope someone can help.
I have noticed that 1 file from the DVD did not get copied over when I RIPed it with "1 Click DVD Copy" but all the video is still there..
Also DVD Shrink can't open it cause there are errors or something in _o.VOB
Fishy if you ask me...
Thanks In Advance
You could try using tools that weren't discontinued over a year ago
Rip again with DVDFab HD Decrypter. Keep it updated (at least one a fortnight) and your success rate will increase.Read my blog here.
AnyDVD is more robust, but like DVDFab HD Decrypter, it needs to be frequently updated.
If you use AnyDVD, be sure to turn off all copy protection ripping features in DVD Decrypter's preferences.Read my blog here.
tsMuxeR and Audio Lag
By imrealdumb in forum Video ConversionReplies: 3Last Post: 14th Jun 2011, 19:28 -
DVD Rip : Audio & Video Lengths Differ
By foochuck in forum DVD RippingReplies: 3Last Post: 1st Mar 2010, 19:23 -
DVD to H264 with Triple Audio (Vorbis) - results only in lag when playing
By Dannyramsnes in forum DVD RippingReplies: 9Last Post: 8th Sep 2008, 11:31 -
Audio/Video Out of Sync/Lag When Editing Clips
By DrawnIntoIt88 in forum EditingReplies: 2Last Post: 15th Dec 2007, 09:03 -
Video Stutter / Skip when coverting from DVD to VOB / MPEG2 file
By afs_nj in forum MacReplies: 2Last Post: 13th Jul 2007, 16:39
