I want to setup custom setting in premiere pro 2.
Editing Mode: Desktop
Timebase: 24.00 frames/second
pixel aspect ratio: D1/DV NTSC (0.9)
Fields: No Fields(progressive scan)
Display Format: 24fps timecode
And I want to export AVI 29.97 fps . Is it OK? My computer performance is too slow, so I used to edit 24 frames/seconds. But If I increase fps, the performance will be slower??
As far as I know, Premier (Adobe) recommend not to change settings during editing. Keep them same as input file.
On export you can do what you want. For export to DVD(NTSC) 29.97 is standard, unless you perform 2:3 pulldown on video later. -
so export with different fps don't cause bad quality video?
I thought input setting and output setting should be the same to keep good quality.
so if I setup 24 fps for editing, it is faster than 29.97 fps editing?? -
I do not know what file you are importing, but rule is input should match the file.
Output is a mater of encoder. If you have any other encoder which you feel will do better job, that output as avi and convert with other.
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 04:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
