I have DVD Flick ver 1.2.2.1 build 442
This is the 1st time i've had to add subtitles with this prog and it fails at the "add subtitle" phase.
I'm adding a seperate .srt file with DVD Flick - Edit title->Subtitles->Add->Edit.Only thing i did was check the "Force subtitles" box.
Is it possible to process the avi with Flick and add the subtitle afterwards?Any suggestions on getting this sorted would be appreciated.
Here's a copy of the error log :
Code:DVD Flick error log Error number 0 from : *** Project info EncodingProfile 3 ThreadCount 2 TwoPassEncode 0 OverScan 0, 2.2 *** Project sources c:\movies\atonement[2007]dvdrip[eng]-fxg\atonement[2007]dvdrip[eng]-fxg.avi IsAVI True TimeStamp 01/01/2008 02:53:14 Stream 0 (2) Duration 7071.4 StartTime 0 Compression mpeg4 BitRate 0 Index 0 608x336 25 FPS DisplayAR 1 SourceAR 1.809524 Stream 1 (1) Duration 7071.4 StartTime 0 Compression mp3 BitRate 96 Index 1 Channels 2 SampleRate 32000 Delay 0 *** dvdflick.log 06:33:06: DVD Flick 1.2.2.1 build 442 06:33:06: Calculating stream sizes... 06:33:06: Disc space used : 4353006 KB 06:33:06: Average bitrate : 4636 Kbit/s 06:33:06: Total duration : 1:57:51 hours 06:33:06: 1 title(s). 06:33:06: Using Best encoding profile. 06:33:06: Encoding to pal-dvd 06:33:06: Encoding video... 06:33:06: Title 0, source 0 06:33:06: Source : c:\movies\atonement[2007]dvdrip[eng]-fxg\atonement[2007]dvdrip[eng]-fxg.avi 06:33:06: Properties : 608x336, 1.81:1, 1:1, 25 FPS, mpeg4, 7071.4 seconds 06:33:06: Target BitRate : 4636 Kbit\s 06:33:06: Recompressing 06:33:06: C:\Program Files\DVD Flick\ffmpeg.exe -i "c:\movies\atonement[2007]dvdrip[eng]-fxg\atonement[2007]dvdrip[eng]-fxg.avi" -s 720x564 -padtop 6 -padbottom 6 -r 25 -g 15 -vcodec mpeg2video -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -aspect 16:9 -minrate 4636k -maxrate 4636k -b 4636k -preme 1 -precmp 2 -subcmp 8 -mbcmp 8 -cmp 1 -mbd 2 -sws_flags spline -sc_threshold -9000 -bf 1 -an -threads 2 -fflags genpts -strict 2 -f mpeg2video "C:\Documents and Settings\My Documents\DVD\0.0.m2v" -map 0:0 *** ffmpeg_video_title0_source0_pass0.txt bits/s frame= 718 fps= 41 q=2.5 size= 16175kB time=28.6 bitrate=4626.5kbits/s frame= 746 fps= 41 q=2.5 size= 16808kB time=29.8 bitrate=4626.8kbits/s frame= 775 fps= 42 q=1.6 size= 17465kB time=30.9 bitrate=4627.2kbits/s frame= 805 fps= 42 q=2.0 size= 18144kB time=32.1 bitrate=4627.5kbits/s frame= 835 fps= 42 q=2.0 size= 18823kB time=33.3 bitrate=4627.8kbits/s frame= 866 fps= 43 q=2.5 size= 19525kB time=34.6 bitrate=4628.1kbits/s frame= 897 fps= 43 q=1.6 size= 20227kB time=35.8 bitrate=4628.4kbits/s frame= 927 fps= 44 q=2.0 size= 20906kB time=37.0 bitrate=4628.6kbits/s frame= 957 fps= 44 q=2.0 size= 21585kB time=38.2 bitrate=4628.8kbits/s frame= 988 fps= 45 q=2.5 size= 22286kB time=39.4 bitrate=4629.1kbits/s frame= 1018 fps= 45 q=2.5 size= 22966kB time=40.6 bitrate=4629.3kbits/s frame= 1048 fps= 45 q=2.5 size= 23645kB time=41.8 bitrate=4629.5kbits/s frame= 1078 fps= 46 q=2.5 size= 24324kB time=43.0 bitrate=4629.6kbits/s *** Project destination folder 0.0.m2v 24907516 Winamp media file dvdflick.log 1184 Text Document errorlog.txt 0 Text Document ffmpeg_video_title0_source0_pass0.txt 5360 Text Document title0.temp 0 TEMP File *** Drives A - not ready C - Local Disk DriveType 2 FileSystem NTFS AvailableSpace 22534 FreeSpace 22534 TotalSize 149448 D - DriveType 2 FileSystem FAT32 AvailableSpace 2092 FreeSpace 2092 TotalSize 76274 E - not ready F - not ready
Closed Thread
Problem adding subtitle in MKV
By burple in forum SubtitleReplies: 2Last Post: 7th Nov 2011, 11:34 -
Subtitle timing problem, DVD created using DVD Flick
By Vianty in forum Authoring (DVD)Replies: 8Last Post: 28th Apr 2010, 03:33 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
Problem with adding subtitle to a TV Series DVD
By hellbound in forum SubtitleReplies: 3Last Post: 2nd Sep 2009, 16:56 -
Any idea about this problem ( adding subtitle to a Dvd )
By khatab1 in forum SubtitleReplies: 4Last Post: 15th Sep 2008, 12:05
