I upgraded one of my four computers from a Socket A mobo to a newer AM2 mobo. The newer mobo only has one ide channel and two SATA ports. I have 3 IDE hard drives and one DVD-Rw/+Rw burner...
I know I can purchase a pci IDE card as I already have two of them by Promise in two other computers. But I would prefer to use an IDE to SATA adapter. I've seen them listed but I was wondering if there are any issues with them?
Thanks kindly...
instead of using a IDE to SATA adapter buy a PCI CONTROLLER CARD for your hard drives. or buy a PCI CONTROLLER CARD w/the SILICON IMAGE CHIPSET for your dvd burner. PROMISE CHIPSET's will not work crorrectly with DVD BURNERS. just my 2 cents!
Sorry...but as I mentioned in my first post, I know about pci ATA controller cards... As I said I already have two...
I'm asking about ide to sata adapters. That is what I'm asking.
Cheers -
www.newegg.com
you'll have to read the reviews and get one that specifically works with optical drives -
Zoobie...great idea!!!
Budz...thanks for the tip on silicom image chipsets...
Appreciate the replies...
SATA to IDE adapter.
By Poppa_Meth in forum ComputerReplies: 31Last Post: 6th Jan 2014, 15:47 -
esata & sata adapter
By neworldman in forum ComputerReplies: 17Last Post: 31st Dec 2010, 20:08 -
IDE and SATA
By HotDamn! in forum DVD & Blu-ray RecordersReplies: 11Last Post: 6th Mar 2010, 00:49 -
sata vd ide
By dymx in forum ComputerReplies: 3Last Post: 9th Sep 2009, 08:04 -
Sata v.s IDE
By tapal in forum ComputerReplies: 4Last Post: 22nd May 2008, 05:04
