Hi all...
I am really confused on what I may be doing wrong. I have a stand alone DVD player now, by Sanyo, it is great and plays everything. My problem is the quality of the vcds and svcds are really lacking and I am not sure if it is because of something I am doing or not doing. I am capture with a ATI all in wonder RAdeon, using 352x240 at 1.15 m/bit for vcd 2.o and 480x480 at 2.52m/bit for svcd and then I use vcdeasy to burn them. I used the vcd guide on the site and have it set to be close to 2.0 compliant. They both play in the machine, but the quality of the vcd is pretty bad and the quality of the svcd is around that of an old video tape, and not as good as I though it would be. Any suggestions or ideas you can relay to me to make them look better or a way to do xvcd or something like that would really be appreciated..
Thanks a ton...
Results 1 to 1 of 1
Codec Newbie Needs Help
By Canyonmaid in forum MacReplies: 8Last Post: 23rd Jun 2011, 19:25 -
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43
