i wanted to know that i have added a clip of one hour in sonic vegas. i wanted to add multiple video effects to the clip. But when i add a effect it is applied to the whole clip. Plz tell me how to apply effect to a particular part of the clip as i wanted to add more effect to other part.
Plz tell me
What version ? Sonic Foundry haven't owned Vegas in a long time.
Regardless, you have two choices
1. Split the clip (S key) into chunks and apply the effects to the chunks. The splits will not affect playback and will be seamless during encoding
2. Use the key frames on each effect. This is my preferred method as it is more subtle and allows for far greater control, as well as leaving open the ability to mix effects if necessaryRead my blog here.
Again I ask : what version are you using ? Sonic Foundry have not owned Vegas for several years. The versions under the Sonic banner were pre DVD and did not have DVD burning capabilities. Do you have an old Sonic version, or a newer, Sony version. Is it Vegas Movie Studio or Vegas Pro ? Help us help you by provinding real information.
Read my blog here.
Hello..been a long time-Can I upgrade from vegas 5.0 and DVD arch 2.0 to Vegas Pro 9
By arcorob in forum Newbie / General discussionsReplies: 6Last Post: 1st Feb 2010, 20:31 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 00:41 -
Sonic Vegas
By m baqar in forum Authoring (DVD)Replies: 9Last Post: 3rd Apr 2008, 04:29 -
sonic vegas
By m baqar in forum Authoring (VCD/SVCD)Replies: 1Last Post: 2nd Apr 2008, 01:29 -
Vegas Movie Studio Vs Vegas. Crippled levels?
By fredfillis in forum EditingReplies: 0Last Post: 3rd Jul 2007, 15:16
