I'd like to be able to set the book type for +R discs to DVD-ROM, but when I attempt to do so in Img Burn I get an "Incorrect Function" error. Anyone know what the issue might be?
You might look at this post at the ImgBurn forum: http://forum.imgburn.com/index.php?showtopic=6482
I don't know if it's connected with SP1, but that's a possibility. I would uninstall ImgBurn, then re-install and see if that changes anything. Bittsetting is the default setting if you are using DVD + media and Samsung drives. They should show as 'TSSTcorp'. I have SP1 on my Vista 32 laptop that has a Samsung burner and I don't see that the DVD burner driver has been updated. Or the IDE/ATA controller drivers. I suppose it's possible something already toggled the bitsetting on and ImgBrun toggled it back to unset. -
Thanks for the reply. I tried uninstalling and then installing the new version released today but I still have the same issue. Like the person in the thread to which you linked, I too am running x64 Vista SP1. So perhaps this is an x64 issue? I take it you can change the book type on your laptop?
nothings wrong with the SAMSUNG 203N drive when it comes to burning DVD+R media. it gives me the same error msg as well but the DVD+R media is booktyped to DVD-ROM. have you tried burning a DVD+R media with IMGBURN? try one then after it's burned you can see via IMGBURN that the disc was burned to DVDROM.
This is the error msg that I get with my S203B drive.Originally Posted by redwudz
Sorry it wasn't the exact error the OP mentioned. It could just be a error on IMGBURN's part. When doing a quality scan with a DVD-R disc burned in a S203B drive it will show up in CD/DVD SPEED that the disc was burned with a SAMSUNG 183L drive. Go figure!
The quality scans using CD/DVD SPEED are used with BENQ & LITEON dvd burners. So it could also be a SAMSUNG error where the engineers were lazy or something.
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
I/O Error in IMG Burn - Help!
By msdker in forum Newbie / General discussionsReplies: 7Last Post: 22nd May 2008, 00:11 -
Is there an MPEG2 editor that will let me change its audio type?
By Nuke Shower in forum Video ConversionReplies: 6Last Post: 9th Apr 2008, 17:00 -
book type management
By MasterThomasMI in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2007, 14:23 -
Pioneer DVR112 book type setting?
By tac7 in forum DVD & Blu-ray WritersReplies: 3Last Post: 26th May 2007, 17:02
