  1. Hi,
    Does it exist some software that can build a "recovery" file (like in Winrar which allows to add some percents of recovery datas) from all the files stored on a freshly burned dvd ?
    Ie: I burn a dvd with hundreds of holiday photos on a single dvd but sometimes dvd's tends to become unreadable after several years. So if some files become damaged, they can be repaired from the recovery file.
    Thanks.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    For important data, have two copies on quality media.
    Google is your Friend
