    Dec 2005
    Belgium
    Hi,
    I live in Belgium, and have recently bought a Telenet Digicorder.
    the best specifications I can find are here at the top of the page. Click on 'Kijk op de achterzijde.' I'll try and translate for those who don't speak Dutch.
    1-Power Connection
    2-Ventilator
    3-RF In for the Aerial Cable
    4-RF Out to the TV
    5-Ethernet Port
    6-DD Surround Sound Connection
    7-SCART Out to TV
    8-SCART Out to Another Device
    It allows you to record programs to an internal hard drive, though mine is rapidly becoming full. What would be the easiest way to record from this device to either VHS or DVD? Would I lose quality if I were to try and record the 2nd SCART Out? Is it possible to connect it to a PC easily?
  2. AGAINST IDLE SIT nwo's Avatar
    Jan 2004
    Stadium Of Light
    s-vhs scart would be the best quality you will get from the box, or move the video to your pc with the ethernet and convert to dvd.
  3. I don't think it's easy to get something out of the ethernet cable.. and I tried to copy the HD inside.. but telenet is using its own filesystem.. Later on I read a couple of articles about it on the web.. (people are trieing to hack the filesystem to replace with larger HD etc.. but nobody succeeded yet..)
    more info: http://idtv-forum.telenet-esp.be/archive/index.php/t-824.html
    info & pictures: http://www.tik.be/forum/viewtopic.php?f=25&t=4846
    only way to do this job is analog I sadly think..
    Nov 2006
    Belgium
    Hi,
    do you have a dvd recorder?
    Capture with the dvd recorder with direct recording when playing on tv.
    Peter, Belgium.
