Hi there,
2 questions:
What's the best way to burn a dvd image of a movie?
What's the best kind of DVD to use?
I've had the most success mounting the image and burning it through the "Burn DVD from Video TS folder" option in Toast.
I was also told that DVD-R is compatible with most DVD players so I don't use DVD+R.
However I recently burned a DVD-R that seemed perfectly fine but part of it started skipping at the end.
I'm pretty sure this is a software issue not a scratched DVD issue.
Thanks.
1. Assuming the image file is good, Disk Utility can burn that back to a disc.
2. Verbatim -R (Apple's official recommendation...and they're right) -
I'm pretty sure that it's not a software issue. This is a common problem, and the usual cause is either an iffy burn (can be caused by fingerprints, too) or bad media. The end of the movie is located near the outer edges, so if you are sloppy about handling the discs, any smudges will cause a marginal burn. Also, cheap media may have a combination of runout/poor flatness (causing worsening tracking/focus at the outer edges) and poor reflectivity (reducing signal strength; worse near the outer edges, which spin faster). Slower burns can help, but the best cure is to use high quality media, and to be sure to handle the disc ONLY by the edges. This last consideration is far more important before the burn than after (but is always important).Originally Posted by kelman4
If you have Toast then use the Image File setting in the Copy window to burn disc images to disc.Originally Posted by kelman4
The skipping is most likely a media problem. You might try telling Toast to burn at a speed slower than Best. Set the speed after the blank disc is recognized.
How do I burn a dvd with working next/skip feature?
By JustBecause in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2009, 20:16 -
Correct Settings in Image Burn for HD-DVD?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 17th Jan 2009, 18:01 -
Is there any way to burn a dvd that can't be copied or made into image
By yozloy in forum Authoring (DVD)Replies: 7Last Post: 17th Oct 2008, 22:54 -
Can't burn .iso image file onto the DVD+R
By BabaKali in forum Newbie / General discussionsReplies: 12Last Post: 26th Sep 2007, 06:44
