I'm a total newbie when it comes to troubleshooting, I basically know my way around programs such as DVD Decrypter & DVD Shrink.
The problem I've been having for a while now is that when I start to rip or burn a DVD the speed goes from 5x to 0.4x in a matter of a minute and stays that way throughout the process. I use a Pioneer DVR-108, and have just recently gotten an Asus DRW-2014L1, both having abysmal read/write speeds. I have two hard drives connected via usb 1.1 which I send/receive data to/from, I don't know if that may be the problem.
	check to see if your dvd burners are stuck in PIO mode. they need to be in DMA mode. check the link below on how to set to DMA mode.
 http://www.cdrlabs.com/forum/viewtopic.php?t=7625
 if your dvd burners are in DMA mode then the problem could exist in the usb 1.1 hard drives.
	Well both are set in DMA mode, so I guess it's the USB hard drives.
 Thanks for helping
	If your hardware is capable of it, upgrading to USB 2.0 will increase transfer rates a bunch.Originally Posted by happy.hrvat
 http://support.microsoft.com/kb/329632
 If your hardware is NOT capable as-is, you can add a USB 2.0 PCI card, they're cheap.Pull! Bang! Darn!
	Definitely upgrade to USB 2.0 somehow, it might even be as simple as enabling it in your BIOS, if not then take fritzi93's advice and get a 2.0 card. I once tried to rip a DVD on my sister's computer with only USB 1.1. A movie that usually only took about 10mins took over an hour! I you have the space and connections I would recommend installing the HDD internally. To give you an idea the data transfer rate of USB 1.1 is only about 12Mbps while 2.0 is up to 480Mbps. You can fool some people all the time,you can fool some people part of the time, but you can't fool everybody all the time
	Yeah, I tried ripping a DVD last night straight to my hard drive, worked like a charm, fastest speeds I've seen in months! And just now I updated my drivers, and my dvd read speads are off the charts, I'm getting 12.5x speeds, this is amazing.
 THANK YOU SO MUCH FRITZI93,   !!! !!!
  DVD Burning causes Extremly slow playbackBy PowerFalcon in forum DVD RippingReplies: 4Last Post: 27th Aug 2011, 16:47
  Dvd slow burningBy Psco2007 in forum Authoring (DVD)Replies: 29Last Post: 8th Dec 2010, 16:09
  DVD ripping incredibly slowBy moults in forum DVD & Blu-ray WritersReplies: 12Last Post: 18th Jul 2010, 16:31
  Very slow DVD ripping in Windows 7By stephens in forum DVD RippingReplies: 16Last Post: 5th Mar 2010, 10:39
  DVD Decrypter / DVD Fab - Extremely slow ripping speeds in VistaBy awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 14:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
