I've been using Wincapture for the past two weeks and it works fine for the most part (85 -90%), however it does crash once in a while.
I also tried out CamStudio (which is free), however this thing won't do the audio part and it works only 50% of the time especially if the captured file contained audio.
I'm basically using these softwares to capture what I see/hear on screen like streaming of live cams, so is there any alternatives to the above two?
Thanks and best regards.
	Greets,
 You can also try VirtualDub and VirtualVCR for captures. VirtualVCR needs to be set up in a certain order from what I recall. A Google search for a guide on it or it's homepage should get you that info.
 Oops, missed the streaming web cam part. Not had my morning coffee yet. There is also a Bulent (not sure on it's exact spelling) Screen Recorder. Search out the older freeware version. Newer one is crippled in some way as I remember.
 Cheers,
 RickRene: Could you not just wound him a little bit?
 Hans: Well now, with a 25 pound shell that is not easy.
 'Allo 'Allo
  Bad screen captureBy Khalua in forum ComputerReplies: 1Last Post: 9th Mar 2011, 17:44
  Best video capture software? Is AVI better for capture? Is TV screen betterBy johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17
  Video screen captureBy cottage in forum Capturing and VCRReplies: 5Last Post: 9th Dec 2010, 16:37
  Continuous Screen CaptureBy pchan in forum ComputerReplies: 1Last Post: 24th Sep 2007, 03:09
  Screen CaptureBy RoadRunner01 in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2007, 08:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
