Here is my current home network configuration. My wireless router just died and I need a replacement.
I was using a Linksys WRT54G. Before simply replacing the unit, is there a better network configuration I might put together? At present, I have 4 computers, a print-server, and media player attached to a Netgear 8-port Gigabit switch. I only use the wireless router for Laptops in the house. I'm using Cat-5E cabling between the DSL Modem, Router, and Switch and Cat 6 cabling between the Switch and other components. Any comments and suggestions would be appreciated. Thanks in advance.
wwaag
Your design looks just fine as it is. You've got your highest bandwidth-demanding devices connected to your highest bandwidth device, and on down from there. I would not recommend changing it unless you have a compelling reason to do so -- which does not appear to be the case.
I would recommend carefully researching your replacement wireless router so that you get the most bang for your buck. -
Not certain - I like NetGear stuff, but pretty much got beaten down for being critical of Linksys stuff: Even after watching three WRT54G's dying in a month, and being stupid enough to complain. I've been running NetGear for over a year without many issues - just an occasional reboot.
Have you tried a reboot?;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Can't use one of my XP pc's on network (Network experts)
By neworldman in forum ComputerReplies: 5Last Post: 21st Jan 2011, 15:12 -
AVIDemux 1-pass vs. 2-pass Configuration Question
By robindean in forum Video ConversionReplies: 2Last Post: 12th Mar 2010, 19:32 -
Network Printer Question
By Frank-0-Video in forum ComputerReplies: 4Last Post: 17th Feb 2009, 06:19 -
Network printer on separate network?
By Lucifers_Ghost in forum ComputerReplies: 7Last Post: 5th Dec 2008, 13:52 -
Home network question
By rubberman in forum ComputerReplies: 2Last Post: 26th Feb 2008, 11:45
