I made a a dvd using ConvertxtoDVD with menu from downloaded files, the original works fine but now when i try to copy it the menu doesnt not show up, Ive tried riping with dvd decyptor, then creating an iso in dvd shrink, and buring the iso to a dvd. when previwed in vilc the iso has the menu and it functions, however after it is burned and played on tv, no menu. ive also used imgburn and nero to copy wtih same results.
Results 1 to 19 of 19
no need to re-rip it as it's not protected. use windows to copy the video_ts and audio_ts folders off of the original dvdr to a folder on your hard drive. use imgburn in build mode to burn from your hard drive onto dvdr. 1 to 1 copy nothing will have changed.
what program in windows do i use to create the video_ts and audio_ts files? will the folder files be dvd files and imgburn basically create an iso to burn to a dvd? i think i already did a similar senario to that as I used the copy disc function in nero and burned the dvd, but the menu did not show.
From what I understand, you have a disc, made with ConvertxtoDVD,
that is fine, play with menu and all.
To copy you can use Nero/Disc Copy or if you want to use ImgBurn, than
put your disc into drive, click off on play, open Explorer, find the drive and use "Open". You will see two folders Audio and Video_TS.
Create folder on your drive with name of the movie or what you like, than drag those two folder from DVD to HDD folder you created.
Once done, open in ImgBurn Build mode, if you have new version, than use corresponding icons in open menu, than burn. -
brdhsby5 - dvds are data discs. nothing fancy and can be copied just like any file on your computer. insert your disc. rightclick on drive icon. select open or explore. there should be 2 folders. highlight them and drag them to your harddrive, into whatever folder you want there. when it's done, give the folder the name of the movie if you want that as the disc label. start imgburn. select mode/build. click the little folder icon in the upper middle. navigate to the movie folder and select it. insert a blank dvdr. when the folder->disc icon lights up click it and follow the instructions. when it 's done it will be a 1 to 1 copy.
I tried what you told me, still same result. Well the actual disc plays just the menu doesnt not appear it just auto plays from the beginning on the episode then when it reaches the end of that it stops. is there some sort of coninuation i can turn off or check off? the originals copys menu works fine, i dont know why this one isnt showing up.
drag the video ts file from your dvd drive right into convertxtodvd -under action
burn already converted file -wil copy burn entire video ts file -
i dont have the already completed file as i have set up as delete when finsihed burning. i dragged the files off the disk to hard drive and burned it that way but still same result. file does play but i cannot select files off a menu that appears in original. im guessing there some sort of continuation/autoplay feature i need to to disable?
im talking about a dvd made originally with convertxdvd, not an original one
OK, now we are clear.
Once you drag files to HD, can you play those in software player and it is starting with menu? -
From what I get in first and last post, you created DVD from few files imported into ConvertX and use that program to create menu for them to play from.
I am not familiar with ConvertX, but I assume it create new folder on HD with your new compilation.
Does that play, usig software player like VLC, starting from menu?
Forget PgcEdit, that is just to be able to check commands, beside other things it can do.. -
i deleted the original files, now i just drag them off the disc to the hard drive directly, when i create an .iso the menu shows up but after i burn nada, i hit play it fails to load, then have to hit play again, it plays for the first ep, no menu. after the first ep finishes it goes back to beginning, no menu
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 10:14 -
Replacing DVD menu made by ConvertXtoDVD
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 4th Oct 2010, 05:39 -
editing text in menu in an already made dvd
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2008, 22:32 -
Error with ConvertXDVD
By MannyNoela in forum Authoring (DVD)Replies: 2Last Post: 20th Mar 2008, 06:17 -
sonydvdarchitect4: cannot make copy from dvd which was made by architect
By mark70725 in forum Authoring (DVD)Replies: 7Last Post: 7th Jun 2007, 09:48
