Results 1 to 9 of 9
  1. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    I have tried numerous program trying to convert to ipod video and all have come out with audio and video out of sync. I can't seem to figure out what i'm doing wrong. Any suggestions. Thanx all.
    I reject your reality
    and substitute my own.
    - Adam Savage -
    - Mythbusters -
    MP3 VBR source audio? Or does it happen with allllllllllllllllllllllllllll video sources?
    I would use Ripbot264.
  3. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    It happens with all video sources mainly mpg and divx.
    - Adam Savage -
    - Mythbusters -
    Is the mp4 ipod video out of sync on both your computer and ipod?
    Tried Ripbot264?
  5. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    yes when i play on both
    - Adam Savage -
    - Mythbusters -
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Assuming the original file(s) are OK, it is typically the conversion process (ie: tool used) that creates the out of sync issue and you may end up needing more than a single tool depending on the various types of source files you are using.
    You can look in the Tools section for a list of apps that can be used for iPod conversions (Portable/Mobile/PSP/iPod).
    Google is your Friend
    Apr 2004
    Miskatonic U
    I use Videora mostly. Occasionally I will get an out sync video. To get around this I have created a couple of fixed framerate profiles which generally solves the problem.
    Read my blog here.
  8. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    I've tried a number of programs and had the best luck using ADS Instant Video To-Go.
    http://www.adstech.com/products/RDX-160/intro/RDX-160_intro.asp?pid=RDX-160
  9. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    A good little payware program is from Jesterware. No, I definitely wouldn't archive these conversions, but if you want a quick reliable, no-nonsense, working file that plays solidly on your iPod, you shouldn't go wrong. Been using it over a year now.
    Nero Recode is very good too.
    If you're converting directly from DvD, then HandBrake is ultimate. Free too.
    BTW - I personally believe, that if you're only encoding for iPod, not archiving, stick with the older, and quicker-to-encode-to, MPEG-4. With all resources involved in H.264, long encoding times, and buggy tools still for it, is just not worth it for a program you'll watch then delete on your iPod - even if the quality is better. Who cares? It's an iPod, not a big screen.
    I hate VHS. I always did.
