This past weekend I filmed a live concert; about 2 hrs of video using my Panasonic AG DVC 30 camcorder with MiniDV tapes. When I got home I discovered that the video recorded fine but the audio was nonexistent or would come on for about a second and then skip off. I tried connecting it to my TV, listening through the camera mic, and downloading/extracting it to Final Cut and it was the same in all mediums. I also put a new tape in and checked that the mic on the camcorder wasn't blow out and it worked fine. My mistake, I believe is that I used a couple of tapes to record the concert that I had already used before. Is this the likely issue and more importantly is there any way to recover the sound from the recording?
Try playing the tape back in a different camera if you can. If you still don;t audio there may not be anything 'there' to recover. I reuse tapes all the time and have never had just the audio drop. On the RARE times there was a problem I would get video blocking first/too.
Hope it works out for you.
Recovering quiet audio
By ReedJohansson in forum AudioReplies: 6Last Post: 20th Mar 2012, 05:03 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
Sony Vegas Capturing Outside Audio instead of MiniDV Audio
By RKelly in forum Capturing and VCRReplies: 3Last Post: 29th May 2008, 08:22 -
Recovering scratched audio CD
By Des in forum AudioReplies: 11Last Post: 31st Mar 2008, 07:54 -
miniDV to hard drive to miniDV while preserving time and date?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 21:46
