Can anyone plz tell me how to add scrolling text to my video. I want to add my name, phone number etc on my clip as scrolling text
http://www.google.com/search?hl=en&q=premiere+scrolling+text&btnG=Google+Search
One of those looks like it'll help.
Good luck.Want my help? Ask here! (not via PM!)
If you have CS3, or CS2, or Premiere Pro, This is so obvious you shouldn't be asking the question.
There are several ways to get explanations. The one everyone overlooks is to RTFM.
Second, is to click on "HELP" at the top right in Premiere, and either index it and look for titles, or rolling titles, or don't index it and under contents, choose
"Using the Titler", and under that at the bottom, choose "Rolling and Crawling Titles"
That should get you going.
The other and more direct way is to simply go to "File-New-Title". Give it a name and it will open up the titler window.
At the top of the window towards the left should be a box with some horizontal lines (text) with an up and down arrow to the right. If you put your mouse cursor over that, it will say "Roll-Crawl Options". Click on that. There will be a new window open where you choose what type of title it is. The default type is "Still". Click on Roll or crawl....whichever you want and then fill in the options. I normally choose my start and end off screen. That is all. Then just start typing away what you want and take care of it in the titler. When you are done, exit the titler and it will save it and put it in your project list. From there you can put it on the timeline on a video track and extend/stretch it for the length you want.
It is just a regular title that you set up with spacing, fonts, colors, fills, outlines, etc., but just make it roll or scroll.
You'll have to play with it to finalize it the way you want, but that is what you do.
Premier Pro CS3 exporting problem
By SB4 in forum EditingReplies: 0Last Post: 13th Dec 2010, 09:50 -
HV30, Premier Pro CS3, Output Settings
By aprilsnow in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 27th Oct 2008, 22:31 -
MPEG2 file plays in windows media player but not properly in premier cs3
By ibanezfreak in forum EditingReplies: 1Last Post: 20th Oct 2008, 03:42 -
How do you use Adobe Encore CS3?
By zanos in forum Authoring (DVD)Replies: 0Last Post: 24th Apr 2008, 21:04 -
Adobe Premiere CS3 vs 2.0
By hanugro in forum Video ConversionReplies: 0Last Post: 31st Aug 2007, 07:26
