Hey folks, this is my first post and I am most definitely a newb so please bare with me. I am a part of a football coaching website where we constantly burn and trade DVDs with game film, coaching clinics, lessons etc etc. I am trying to build up my own collection of video and in doing so need to learn how to burn DVDs. Now i know the first thing i need is Mac the ripper, which i have. Oh yeah, my machine is a iBook G4 with a 1.33GHZ PowerPC G4 Processor with a 256 mb built in memory.
My question now, how can I take what MTR has given me and turn it into a 2nd copy of my original DVD? i've been around in circles on the internet the past few days and am even more lost then when i started. will i have to drop hundreds of dollars to do this?
thanks in advance
Results 1 to 12 of 12
To burn a VIDEO_TS folder in UDF format, you may need 3rd party tools, like DVD Imager to create a disk image which can be burned in the Finder or Disk Utility.
"Copy of the original DVD"? >>> Apple's Disk Utility will do it all for you. Use that app to create the image file (the .dmg) and then select that image file (which will now be in the left-hand list in the Disk Utility window) and click the Burn button. You'll be prompted to insert a blank disc; do so and click the burn button in the dialog. Done.
so if i use DVD Imager, i can then simply use the Disk Utility burner on my hard drive?
what does DVD imager do? -
rumplestiltskin...
what are my exact steps there (I'm sorry, don't know 100% what you're talking about)?? -
here's an Update: i downloaded DVD imager and created the .img file, mounted it and burned it onto a DVD with the disk utility.
i then re-inserted the DVD to test if it worked, and DVD Player automatically opened so i thought YES IT WORKED. But then to test it, I put it in my PS2 and it couldn't even read it. Did i just make a DVD that only works on a computer? -
Perhaps...
A far easier solution and steps.
1. Rip the Original DVDs with Mac The Ripper.
2. Go buy Toast Titanium ( v.8 or higher)
3. Take the output from MTR on your HD, and
Open Toast. Select the Data selection, select DVD-ROM (UDF).
Drag and drop the output from MTR into the Toast Window.
4. Insert a Blank DVD, click the green burn button in Toast.
Toast then will burn you a compliant DVD that plays in anything.
can't get any easier.
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
If you're talking home-brew DVD's, you don't need MTR. It is only
for commercial copy protected discs.
You can copy the discs via Disk Utility if you do it right: new image
from disc, "CD/DVD master" option. Then burning from the image
will get you a byte-for-byte copy of the original.
Or you can drag the DVD's video_ts folder to a folder on your HD.
Get an old copy of Toast or PopCorn (I have a copy of Popcorn 1
that is gathering dust) and burn to DVD-R that way.Al Bloom -
Here is Apple's webpage for the "duplicate a CD/DVD" instructions:
http://docs.info.apple.com/article.html?artnum=42724 -
Toast 7 then?Originally Posted by CaseyJones
Amazon still has it"Everyone has to learn, so that they can one day teach."
Urban Mac User -
Some DVD players are finicky about the type of discs they'll work with. Some only accept DVD+R, others only DVD-R, others only with certain brands of media, and others work with all types without complaint. The PS2 unfortunately is notorious about being very finicky about burned media. I'm willing to bet that this is your problem, and that you've burned a perfectly fine copy. If you have a standalone DVD player, try playing the disc. I'm willing to bet that it plays fine.Originally Posted by CaseyJones
Edit: Just searched a bit more, and found this tidbit, which may or may not be correct:
Source: http://club.cdfreaks.com/f86/will-changing-dvd-r-booktype-help-compatibility-ps2-games-111525/PS2 DVDR/RW support revisions:
Version 1-3 DVD-R/RW only
Version 4 DVD-R/RW & DVD+R
Version 5-10 DVD-R/RW & DVD+R/RW
If your not sure you can check here what revision yours is at the link below.
http://www.modchip.ca/help/whatps2.php
Version 9 & 10 are the most common PS2's around and it will play either - or + format discs just fine.
So, apparently, media compatibility depends on the particular version of PS2, as well as media type, phase of the moon, cosmic ray flux, and current interest rates.
Best of luck to you!
Getting started, I need to learn EVERYTHING
By hadoq in forum Newbie / General discussionsReplies: 27Last Post: 15th Mar 2011, 00:36 -
Can't Get Started with Streamclip
By cindyjk in forum MacReplies: 20Last Post: 22nd Feb 2010, 15:41 -
How to get Started
By Skylark157 in forum Newbie / General discussionsReplies: 2Last Post: 15th Dec 2009, 18:52 -
Getting Started - MPEGII (VOB) to ?
By GregK in forum DVD RippingReplies: 2Last Post: 13th Dec 2007, 12:40 -
Avitricks getting started
By arcoiris99 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2007, 10:19
