When I built my machine the Core 2 Duo E4500 was $300...the Pentium D 820 was $80 (LOL). So I got the D...now the E4500 is $130.....so my question is, will I notice a big performance increase with the E4500, which runs a bit slower than the Pentium D.
Can't go wrong for the price....just curious. I do not want to spend all that much more than the E4500....
thanks
Results 1 to 15 of 15
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
It depends on what software you run. Tom's Hardware doesn't show a E4500 but the E6420 is probably close:
http://www23.tomshardware.com/cpu_2007.html?modelx=33&model1=899&model2=878&chart=430 -
guess it depends on your motherboard. is 800fsb as high as it will support? if so the e4600 is the fastest you will get as an end of the line cpu. $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115032
and yes with the dual cpu and bigger cache it could double your throughput. the 65nm's also are fairly cool and o/c easily if you're into that. only problem might be a re-install of windows may be required as the multiprocessor hal is completely different than the single. f you just pop it in it may boot ok but it will only be using one cpu not both.--
it's also old power hungry 90nm tech that's no longer produced. if you find one it will cost as much or more than an e series.Originally Posted by jagabo
but no matter which you chose make sure to check at your motherboard manufacturer's website to make sure it supports the chip you want to install.--
He already has an 820. I was refering to your statment that "only problem might be a re-install of windows may be required as the multiprocessor hal is completely different than the single."
doh.... thanks - went right over my head.
I have an older asus p5pe-vm motherboard....800 FSB, the 6420 is 1066 fsb so I am not sure the gain over the 4500.
I tend to do a fair bit of video encode....is the core 2 duo really THAT much better than old Pentium D?
thanks again!!!
it is crazy how prices have fallen!!!!!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
I wasn't suggesting using the 6420 -- I used it in the example simply because it should be close in performance to the 4500. The slightly lower clock speed but higher FSB and larger L2 cache roughly balance each other out.Originally Posted by ron spencer
Yes. The Pentium D was a pretty poor design. It was a knee-jerk reaction to AMD's dual core processors. Basically just two Pentium 4 CPU's quickly bolted together so Intel could say they have a dual core processor too. But you should check the performance of the particular software you use. The architectual improvements don't guaranty that every program will run faster.Originally Posted by ron spencer -
I did not realize the design issues...the 4500 seems to have glowing reviews everywhere I look. So I will probably just get that.
Will XP Pro ALWAYS crap out for a new key with a new CPU? Reinstall is easy, just need to prepare for it and ensure all stuff is backed up.'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Have an older PSP800se that used to have a PentiumD 840. Cpu idled at 50 degrees and hit 75 when video encoding. Changed to the 960, and it now idles at 26 degrees, peaks to 48 while encoding, and gives me an average of 110 fps divx encode speed.
Usually not. If you've made a lot of other hardware changes within the last 6 months you may have to activate again.Originally Posted by ron spencer
ok thanks....sounds like the 4500 is right for price.
appreciate all the advice'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
In games I noticed a huge different between the 805D and the 2.2 Core2Duo
I hacked XP even though it was a legally purchased copy before transferring it via a disc swap to a new PC and have had no problems with it since. It was less hassle than trying to get a new key from MS over the phone which I did attempt. I have not created a duplicate copy of XP so am still within the terms of the single user license.Originally Posted by ron spencer
Core 2 Duo E7500 help
By Greddy4384 in forum ComputerReplies: 10Last Post: 24th Feb 2010, 18:00 -
Core 2 Duo VS Core 2 Quad
By vid83 in forum ComputerReplies: 21Last Post: 1st Sep 2009, 22:41 -
Intel Core 2 Duo T7500 2.20 vs. Intel Core 2 Duo E8400 3.0
By vatkat234 in forum ComputerReplies: 6Last Post: 27th May 2009, 11:42 -
Intel Core 2 Quad 9550 or Core 2 Duo 8600 for games...
By retroborg in forum ComputerReplies: 11Last Post: 11th Oct 2008, 22:23 -
Intel E6600 Core 2 Duo MB recommendations
By mysticmel in forum Newbie / General discussionsReplies: 7Last Post: 9th Jun 2007, 04:02
