Results 1 to 12 of 12
  1. How to transform the audio tapes to CD? Does somebody has a similar expereince? Thanks in advance
  2. 1a.Get a RCA "Y" splitter that has a 3.5mm plug,connect Line-Out on tape deck to Line-In jack on soundcard.(Recommended)
    1b.Use headphone jack on player to connect to Line-In on soundcard,need cable with stereo 3.5mm plug on both ends.
    2.Use CDWave or Audacity to record and split into tracks,save as WAV.When recording make sure the level doesn't go higher than -1dB(~90%).
    3.Use Nero,etc to burn.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Or if you have a lot of tapes and wanna spend $100.00
    http://cgi.ebay.com/PLUS-DECK-2C-Audio-Cassette-Tape-Converter-to-MP3-CD-PC_W0QQitemZ3...QQcmdZViewItem
    Drop it in an open bay and away you go....
    Might be able to find them cheaper i did not look around.
  4. Thanks for alla explanations.
    I have e great PC that has audio input jacks. My point, is: can I record the sound that comes form CD player, to the PC, using audio recording software like jetaudio etc.?
  5. Originally Posted by MOVIEGEEK
    1b.Use headphone jack on player to connect to Line-In on soundcard,need cable with stereo 3.5mm plug on both .
    I tried this way, but there is no sound coming in to be recorded. I put the Line-in option on my soundcard, but no results...
    Mar 2004
    Make sure your Line-in jack isn't on "mute" in Control Panel.
  7. Originally Posted by jdachik
    How to see that my friend?
    Feb 2003
    U.S.A.
    Click Start > Settings > Control Panel > Sounds and Audio Devices > Audio > Volume
  9. Banned
    Jun 2007
    UNREACHABLE
    OR: "Win"+"R", sndvol32, "Enter".
  10. Member bendixG15's Avatar
    Aug 2004
    Here's a link to Audacity tutorals for common tasks..... may help you out.
    http://audacityteam.org/wiki/index.php?title=Tutorials
    Aug 2002
    South Florida
    I connect my tape recorder to my video card-Line IN and use the computer's sound recorder to record the sound. Make sure Line In is active in your sound card.
  12. Snce I already have a USB turntable, ION iTTUSB model, that has a jack on the top front that takes audio and sends it through the USB jack to the PC I use that process and into Audacity. My brother uses some software which I believe is called EZ Vinyl Converter that exports the captures right into his iTunes. Link to Ions download page with it here. http://www.ion-audio.com/contentmgr/showdetails.php/id/1089/tt/4.
