I just got a Panasonic S53 dvd player and I've been trying to get some video files to play on it properly.
The problems that I'm having are that when I play the movie file, it plays, sound is ok, but the picture is black and white and there is this large blocky distorted scan line that moves up and down the screen.
I have tried multiple formats and the ones that play all have that same problem. I am using DVD+R media.
Formats that I've been using:
Divix
Mpeg4
Mpeg1
Mpeg2
wmv
Xvid
I've also been using Any Video Converter software to convert them and also AVS Video Converter.
Any ideas on what my problem is and how to fix or overcome it would be greatly appreciated.
Results 1 to 11 of 11
Put a DVD in there that you bought at a store near you and see if it plays in color.
Yes it does. I actually put in a DVD that was authored by someone and it worked just fine.
Then what are the sources of these "files" you are attempting to play in the player?
They are avi's. They have a DivX water mark, but one of the programs I used to convert them said they were Xvid. I've read that Xvid is one of the formats that work in my dvd player.
That makes alot of sense seeing as what I'm trying to watch originated on the BBC. How would I convert them over to NTSC?
You may not need to convert. Check the setup menu on your DVD player and if it has an option for video output, set it to NTSC. This will force it to send all video output as NTSC to your TV and should fix your problem. If your DVD player doesn't have this option, then you'll have to convert. Check the guides.Originally Posted by gyzer
So this can still be an issue with the sorces of these videos being in DivX format, but were originally made from PAL format?
Yes....the source of the videos that are playing in B&W were PAL format...that is the problem.Originally Posted by gyzer
I followed one of the guides on this site and that fixed the problem.
Thanks everyone for their help
DVD Palyer - black and white picture
By majstrydwa in forum DVD & Blu-ray PlayersReplies: 10Last Post: 5th Oct 2010, 11:01 -
Black and White picture after connection
By mrs.c in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2008, 13:48 -
Only receive Black & white Picture on TV
By cincsoc442 in forum Video ConversionReplies: 9Last Post: 6th Aug 2008, 10:05 -
Panasonic S53 DVD player
By EvilWaffles in forum Newbie / General discussionsReplies: 2Last Post: 1st Mar 2008, 11:30 -
Panasonic S53 - Region hack
By veloz in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Aug 2007, 13:31
