Hello.
I have a video camera - model SONY DCR DVD505. It is a video camera (standard - not high definition) that burns the video images onto the small DVDs. It works great.
QUESTION: I want to put more than one of these small DVDs into a full size DVD. How do I do it? Is there any freeware to do it?
A. Jackson
If you want to edit them before re-authoring them to a DVD, you might try VOB2MPG and extract them each to a MPEG file. Then you can edit them as desired, with maybe MPEG StreamClip or Cuttermaran. You could then use GUI for dvdauthor to convert to the DVD format and burn as a DVD disc. All freeware. You could keep them as separate videos or combine them together. If separate, just set up the menu in GUI for dvdauthor so you can select which one to play.
TMPGEnc DVD Author works well for this. It isn't free, but it is reasonably priced.
Should non Standard Copy Protected DVDs use the "DVD Video Logo?
By TubeBar in forum Newbie / General discussionsReplies: 10Last Post: 23rd Sep 2013, 17:20 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
Video size too small in Adobe Premiere
By sadievladimir in forum Newbie / General discussionsReplies: 12Last Post: 23rd Mar 2008, 10:15 -
All video types to standard size / format?
By fuzzyvideomunster in forum Video ConversionReplies: 2Last Post: 3rd Jul 2007, 10:50
