"VD hack" needed when (threads > 1) because multithreading also involve encoding lag of VfW as B-frames (and in previous was described decoding lag of VfW). I need mention that "VD hack" option only fix encoding lag not decoding lag (of course you need encode in VirtualDub[Mod] for correct work of this option) but if you decode with DirectShow filter there is not decoding lag (so the decoding lag of B-frames is problem for editing [when using VfW decoder] but not for viewing in DirectShow players).
And about chroma interlaced downsampling bug:
Yes, it treats image as progressive during RGB->YV12 (YUV -> YV12) conversion because during decoding it also treats it as progressive (and if I would make RGB->YV12 conversion in there other way than you will have greater bugs during decoding).
CLI version support only YV12 as input so it don't make any colorspace conversions. So would you see such bug or not depends of how you make RGB->YV12 colorspace conversion (revert conversion during decoding also important) which you feed to CLI x264.Originally Posted by jagabo
Results 31 to 31 of 31
Archiving Home Video
By chuckaug in forum Newbie / General discussionsReplies: 3Last Post: 9th Jan 2011, 01:56 -
Video backup/archiving
By jncr in forum Video ConversionReplies: 4Last Post: 27th Nov 2010, 17:36 -
Smaller MPEG-2 Files?
By DigitalSounds in forum Video ConversionReplies: 12Last Post: 30th Oct 2007, 04:55 -
Archiving old hi-8 video?
By tchambers in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 10th Aug 2007, 16:32 -
Archiving Video
By The Sumerian in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 2nd Jun 2007, 23:15
