well, this is for my friend, ge's got this .DAT file and it is supposed to be a video file, the person he's got the file from mentioned to use PowerDVD to open the file, I tried it but PowerDVD won't do anything.
Does the file need any convertion to something else to then be able to open in PowerDVD or other DVD player program?
Please help
Originally Posted by geek2330
I've just recently installed Orbit Downloader, which looks promising and is free. Other tools in this category (though not necessarily free) include SDP Multimedia, Net Transport, StreamClip, and WMRecorder. I expect to audition more of these, until my toolbox is sufficiently well equipped. If your avatar indicates that you are a LInux user, I don't know what to recommend to you.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form. -
I will find out from my friend how the file was captured for sure, he had told me it was recorded from a channel but wasn't sure enough, the file came from (I think he's from Macedonia or a similar place.....)......
I will call him so he can check exactly how the file was obtained, this might help better......will post back then.... -
If it really is a video file, it's likely a MPEG-1 .dat from a VCD file. If so, you could just rename the extension to .mpg and try it that way. Or you can drop it into Gspot and it should be able to tell you more about it. You could also play it back with VLC as is. The .dat extension is also used for other purposes besides video as a 'data' type of file.
See 'WHAT IS' VCD to the upper left on this page for informationon that sort of .dat file. -
thanks redwudz, I changed the extension to MPG and I'm able to play the file in realplayer or windows media player.
Now I'll use SVDC2DVD to convert to VOB and then Imgburn to burn on a dvd....
thanks much for chiming in...!!!
3d subtitles don't regonise it at all - srt to all converter program
By fits79 in forum SubtitleReplies: 40Last Post: 9th Apr 2017, 06:31 -
No program will open at all.
By Akhet in forum ComputerReplies: 26Last Post: 14th Dec 2011, 17:32 -
problem: flv files don't open in Vegas pro 10
By freestyler09 in forum EditingReplies: 2Last Post: 25th Feb 2011, 12:57 -
Video files open but don't play
By necrolancer in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2010, 00:24 -
What program to open up a .tv file?
By Gandolff in forum DVB / IPTVReplies: 0Last Post: 12th Sep 2007, 12:28
