Hey guys, i need some help! Been trying to run AutoMKV but it immediately stops responding during 'parsing profiles', forcing me to close it. i tried erasing the profiles folder, but no change. I'm running Vista now, does that matter?
Since i discovered the media center can't stream .avi to the xbox (only wmp11 will - ef'n STUPID) i want to encode to WMV so i can have 5.1 surround AND HD quality. AutoMKV seemed to be the best choice but it don't work. So i either need a solution to get it to run, or a different method to convert DVD to WMV. Thanks for any help!
I am just a worthless liar,
I am just an imbecil -
When I tried AutoMKV some months ago it worked fine in Vista.
Have you installed avisynth 2.5.7, ffdshow and koepis xvid codec? If that wont help I guess you have to ask in the doom9 automkv topic, http://forum.doom9.org/showthread.php?t=134478 -
heck yeah i installed that stuff... that's the same page i used to d/l everything. well damn, i guess i'll see what they say over there.. thanks
So i figured it out! -- i didn't have Net Framework 1.1 installed, i only had 2.0 & 3.0 and apparently that don't work!
Isn't .net framework 1.1 default installed in vista? I can't remember that I have installed it.
Glad you figured it out. I was going to suggest trying the .96b12 beta version of AutoMKV that is out to see if that helps. I'm using that version at the moment and really liking it.
Cheers,
RickRene: Could you not just wound him a little bit?
Hans: Well now, with a 25 pound shell that is not easy.
'Allo 'Allo
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 03:03 -
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 06:33 -
multiAVCHD - anyone else getting "stuck"?
By funnel71 in forum Authoring (Blu-ray)Replies: 5Last Post: 7th Aug 2010, 12:45 -
"Creating" subtitles *solved*
By Meriks in forum SubtitleReplies: 2Last Post: 8th Mar 2008, 16:04 -
I'm totally stuck "unrecognised message" and other errors
By marinebc11 in forum MacReplies: 22Last Post: 26th Aug 2007, 18:32
