Hello Everyone,
After browsing for almost a week over different forums and websites for a reliable and workable solution for PS3 compatible video conversion, I am posting my own queries and confusions over here. Hope any of you would be kind enough to give it a look and reply with practical and tested methods.
My configuration ;
- PS3 40GB Firmware 2.17 (Latest Release) (Using wireless connection)
- Samsung LCD TV 32” LAR32R81 (Connected to PS3 via HDMI)
- Yamaha YHT-185 Home Theatre 5.1 Sound System (Connected to PS3 via Optical Out SPDIF, using Linear PCM sound output from PS3 at the moment)
- Linksys WRTSL54GS Wireless Router with USB Port.
- DSL Home Modem connected to Linksys router.
- External HardDisk Seagate 500GB (As media storage, connected to router USB port)
- 3.6 Ghz, 2GB RAM Dell Optiflex Desktop system running TVersity Media Server. Connected to Linksys router via wired connection to efficiently catalog the audio/video/image media stored. (Since Linksys WRTSL54GS is only UPNP compliant and PS3 needs DLNA enabled devices, so have to put a dedicated PC with TVersity as DLNA media hub)
I have these queries,
Question 1 :
Which AVI Files with XVID play on PS3 and what are their specs. I have tried streaming a number of XVID files to the PS3 , to my surprise some of them work and some don’t without a valid reason. I have installed “MediaInfo”, an excellent program for having a detailed look at your media. I cannot really establish the difference in specs of the XVID movie files which play and the ones which don’t.
All XVID files are encoded with XVID Project Final Version. Audio is MP3 by LAME Encoder and mostly are 2 channel. Only two files have 6 channel audio with unknown codec. (I guess it would be AAC or AC3). Some of them play and some don’t although I have not noted which files don’t play, but as I have read files with resolutions (Width * Height ) not divisble by 16 cannot be played. Is it correct and can be the only factor making them unplayable. I will check if this can be the case. My XVID files have varying sizes starting from 720 x 400 to 512 x 288.
Question 2 :
How can I make the unplayable XVID files playable. I have the following softwares , but not sure which one to use and what are the settings for having minimal degradation in quality when re-enconding in XVID, any presets which are working would be a big help. A direct video stream copy cannot be done in my opinion if resizing needs to be done.
1. AVI Recomp
2. SUPER Media Converter
3. VirtualDub and VirtualDUB Mp3 Freeze.
4. XVID Codec
5. VobSUB
6. AVISynth 2.5
7. ffdShow
8. AC3Filter
9. Mkv2Vob
10. GOTSent
I tried using SUPER with various options to do AVI to AVI conversion which is compatible with PS3 but so far I am unable to do it correctly. Any suggestion and optimal settings regarding which which audio and video codec to use?.
Question 3 :
How to watch High Definition MKV files on PS3. I have tried conversion using Mkv2VOB and GOTSent with various options for Video and Audio. However the same file converted by these two softwares plays too fast on my PC, and NO AUDIO stream is converted thus did not try it on the PS3. . I have read the 4 or 5 step method to convert MKV using various (De)Muxing/Encoding softwares but that seems a lengthy task plus MKV2Vob and GOTsent run all these tasks in batch, just the fact that they are unable to output any sound.
Then tried SUPER to do the same job and AUDIO was converted but file was running too fast in the media player and the whole audio was garbled. Don’t understand what is this problem. Maybe it’s the bitrate being too high, but what should be the correct bitrate. Does PS3 support AAC audio streams.
SUPER Settings for MKV
AVI Container
Codec AVC / H.264 tried DivX/XVID as well.
Audio is MP3 LAME 2 Channel tried AC3 5 Channel (since original file has 5 channel AAC audio)
Mkv2VOB and GOTSent
MP4/MPG/VOB Video having H.264 Video
Mp3/AC3 Audio
Please guide me a conversion method to retain the high quality video (720p) and 5 Channel audio and get a file which is playable on PS3.
The specs of my input file are ;
General #0
Complete name : D:\Media Downloads\backup143\1408_directors_cut_hdrip_x264_[Linkfire.org].mkv
Format : Matroska
File size : 1.43 GiB
PlayTime : 1h 52mn
Bit rate : 1821 Kbps
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video #0
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec profile : High@L5.1
Codec settings, CABAC : Yes
PlayTime : 1h 52mn
Nominal bit rate : 1628 Kbps
Width : 720 pixels
Height : 352 pixels
Display Aspect ratio : 2.045
Frame rate : 23.976 fps
Chroma : 4:2:0
Interlacement : Progressive
Title : Movie
Writing library : x264 - core 58 svn-736M
Encoding settings : cabac=1 / ref=6 / deblock=1:0:-1 / analyse=0x3:0x133 / me=hex / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=1 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=30 / direct=3 / wpredb=1 / bime=1 / keyint=480 / keyint_min=24 / scenecut=40(pre) / rc=2pass / bitrate=1628 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=40 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.5:13.0 / zones=153260,161742,b=0.1
Language : English
Audio #0
Codec : AAC LC-SBR
Codec/Family : AAC
Codec/Info : AAC Low Complexity with Spectral Band Replication
Channel(s) : 6 channels
Channel positions : Front: L R, Rear: L R, Subwoofer
Sampling rate : 48 KHz
Resolution : 16 bits
Title : Nero AAC 6ch Audio
Language : English
Text #0
Codec : UTF-8
Codec/Info : UTF-8 Plain Text
Title : Subtitle
Language : English
General #0
Complete name : D:\Media Downloads\1408_directors_cut_hdrip_x264_[Linkfire.org].mkv.AVI
Format : AVI
Format/Family : RIFF
File size : 764 MiB
PlayTime : 1h 52mn
Bit rate : 950 Kbps
StreamSize : 9.53 MiB
Director : created.with.SUPER(C).v2008.bld.30
Writing application : SUPER(C) - eRightSoft
Here are the specs of my Output file which plays very very fast in any media player on the PC, have not tried it on the PS3.
Video #0
Codec : AVC
Codec/Family : AVC
Codec/Info : Intel H.264
Codec profile : Main@L3.0
PlayTime : 1h 52mn
Bit rate : 810 Kbps
Width : 720 pixels
Height : 352 pixels
Display Aspect ratio : 2.477
Frame rate : 29.970 fps
Resolution : 24 bits
Chroma : 4:2:0
Bits/(Pixel*Frame) : 0.107
StreamSize : 652 MiB
Audio #0
Codec : AC3
PlayTime : 1h 52mn
Bit rate mode : CBR
Bit rate : 128 Kbps
Channel positions : Front: L C R, Rear: L R, Subwoofer
StreamSize : 103 MiB
Thank you for reading my post. I am actually all confused in the things video conversion for PS3 so tried writing down everything in detail. I also need guidance about the various combinations of Audio and Video Codecs (which are playable on PS3), I mean can I convert using any combination of video and audio codecs (Divx / AC3, XVID / MP3) of my choice as available in SUPER converter or there is a specific selection always have to be made every time.
Waiting for help.
Regards,
AlterEgo.
Results 1 to 1 of 1
Having trouble importing avi's (divx/xvid) and mkv's into Vegas 10
By mr-scarface in forum Video ConversionReplies: 11Last Post: 17th Jan 2012, 10:11 -
Best MKV to Avi=divx/xvid
By s-toon in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 15:50 -
Playing HD (.mkv) and XViD\DiVX (.avi, .wmv)
By yonyz in forum Software PlayingReplies: 10Last Post: 25th Feb 2009, 13:18 -
.divx to .avi XviD conversion?
By Benhermies in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2009, 18:15 -
Video not working after x264(MKV) to Divx/Xvid(AVI) conversion using TVC
By CthulhuSaves in forum Video ConversionReplies: 7Last Post: 3rd Jan 2008, 23:12
