We had a PS3 and had to return it. We now have many Blueray movies. We were given a HD player.
I have read about the AVCHD content stored on DVD that will play in a Blueray player. Is there anyway to take our Blueray movies, pull the movie off, then burn them onto DVD using the AVCHD format so we can play them on our HD player?
I hope I asked this correctly.
Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
I was thinking I would by a Blueray ROM for my PC. Here locally I can get one for as little as $130. Players are still around $400.
You're going to have problems in converting BD to HD-DVD.
Native fps is likely to be a major problem, and burning the content will be another.
Why the hell were you given a HD player???Regards,
Rob -
Try using mediacoder.
Rip the files to HD.
import the TS file of the movie into mediacoder.
the output needs to be 1280X720p to fit on a DVD with good picture quality. Set fps to be 29.97.
Then create a folder structure like the one on HD-DVDs.
See if it works.
I am not giving details, because there is a lot of minor steps that I don't have for you. But that is the besic process you need. The big problem is that no one is developing for that since HD-DVD lost the war. everything is only going FROM HD-DVD to BR.
howto play Uncompressed RGB (AVI)
By kamaldeepdung in forum Video ConversionReplies: 33Last Post: 7th Jan 2012, 17:19 -
Any DVD or BlueRay players play HD avi's?
By destro_99 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Dec 2010, 09:38 -
Will 720p record on standard dvd and play in HD on Blueray?
By jimdevo in forum Newbie / General discussionsReplies: 15Last Post: 14th Feb 2010, 14:15 -
Why do HD dvd play chopping using computer versus smooth on blueray player
By CX7 in forum Newbie / General discussionsReplies: 10Last Post: 6th Nov 2008, 18:23 -
WinDVD 9 Plus BlueRay will not play m2ts AVCHD files
By deejay.2001 in forum Software PlayingReplies: 2Last Post: 14th Jul 2008, 09:33
